Thanks for the code that made a big difference for me.
Is there a way to write a macro to add to this that will add a default signature to the macro button when you press reply? Thanks!
The code worked great for me! However i do have a questions. When i use the Reply All button it sends the e-mail to my new default account. Is there a way to stop that? Also, where do i find the option to customize the ribbon on the message screen to customize the buttons there as well?
Thanks for your help!
Doesn't work. I followed the directions to the letter, and got an icon on the toolbar as predicted, but clicking on it gets no response, even with macros enabled, &c. I'm running Outlook 2010 under Windows 7, both with SP1 installed. I've tried every way to get me "Send From" to default to my IMAP account, but in always defaults to my POP3 account, no matter what my settings are or how many subterfuges I try, including this one.
Thank you for this code, works great from the outlook window. In addition to adding these buttons to the ribbon on my home screen I added them to the ribbon inside of an open mail. They work here as well, however, it replies to whichever message I have selected in the main outlook window, not the message I have open. For example, if I were to leave 3 separate emails open, go back to the first one and press reply, it replies to which ever message was last selected in my main outlook window.
I'd love to have this work from inside mail messages as well. I am trying to push this out to a client but am not sure it will be sufficient as is. Any idea how to make this work from inside mail?
Thanks again for the code!
