Outlook 2010 - Always Send from Default Account
  1. Posts : 15,026
    Windows 10 Home 64Bit
    barbarossa2241 said:
    Do these instructions apply to the 2007 version ?
    yes, it is set to the default account by default
    Thanks a lot. I do have Office 2010 but, did not install it yet.
    you're welcome.
    do you have multiple accounts as well?
  2. Posts : 150
    windows 7 home premium 64bit
    you're welcome.
    Just one.
  3. Posts : 15,026
       #12
    you're welcome.
    Just one.
    then you do not need to worry.
    the 'one' account that you use will always be your default while sending & receiving.
    and even if you add another account, you will have the option to choose from which account you want to send :)
  4. Posts : 150
    Got it. Thanks Koolcat77.
  5. Posts : 15,026
       #14
    welcome :)
  6. Posts : 1
    Windows 7 Home Premium 32bit
       #15
    Multiple defaults
    Thanks for the code that made a big difference for me.
  7. Posts : 1
    windows 7 32 bit
       #16
    Add default email signature to macro
    Is there a way to write a macro to add to this that will add a default signature to the macro button when you press reply? Thanks!
  8. Posts : 1
    Windows 7 64bit
       #17
    The code worked great for me! However i do have a questions. When i use the Reply All button it sends the e-mail to my new default account. Is there a way to stop that? Also, where do i find the option to customize the ribbon on the message screen to customize the buttons there as well?
    Thanks for your help!
  9. Posts : 3
    Windows 7 64 Pro
       #18
    Doesn't work. I followed the directions to the letter, and got an icon on the toolbar as predicted, but clicking on it gets no response, even with macros enabled, &c. I'm running Outlook 2010 under Windows 7, both with SP1 installed. I've tried every way to get me "Send From" to default to my IMAP account, but in always defaults to my POP3 account, no matter what my settings are or how many subterfuges I try, including this one.
  10. Posts : 1
    Win7 x64
       #19
    Reply from selected message only!
    The Bergel said:
    Took your idea one step further and created custom Reply, Reply All and Forward buttons.
    In Outlook:
    1. Press alt + F11. This will open up the MS Visual Basic for Applications window.
    a. This is where we’ll input the code for our custom Reply, Reply All and Forward buttons.
    2. Expand the Project1 tree, then right click on the Microsoft Outlook Objects folder.
    a. Chose Insert, then Module
    b. This will create a Modules folder and a Module beneath it. Double click on that module
    3. In the blank area copy and paste the following code (be sure to change “Account Name” to the Outlook account name for your Domain B. Keep the quotes:
    Public Sub New_Mail()
    Dim oAccount As Outlook.Account
    Dim oMail As Outlook.MailItem
    For Each oAccount In Application.Session.Accounts
    If oAccount = "Account Name" Then
    Set oMail = Application.ActiveExplorer.Selection(1).Reply
    oMail.SendUsingAccount = oAccount
    oMail.Display
    End If
    Next
    End Sub
    4. Click in the Name row in the Properties window on the left. Change Module1 (2,3, etc) to Reply.
    5. Click on the Modules folder and do Insert then Module
    a. This creates a new module. Double click and insert the following text
    Set oMail = Application.ActiveExplorer.Selection(1).ReplyAll
    oMail.Display
    End If
    Next
    End Sub
    6. Click in the Name row in the Properties window on the left. Change Module1 (2,3, etc) to ReplyAll
    7. Click on the Modules folder and do Insert then Module again (last time)
    a. Double click and insert the following text
    Set oMail = Application.ActiveExplorer.Selection(1).Forward
    oMail.Display
    End If
    Next
    End Sub
    8. Go to File and Save VbaProjectOTM
    a. Go to File and click Close and return to Microsoft Outlook
    9. Now we’ll add the actual buttons to our ribbon. You’ll need to do these steps for your main ribbon (seen in the Inbox) and the ribbon you see when you open a new mail message.
    10. Go to File, then Options, Customize Ribbon.
    a. Click the dropdown for Choose commands from and click Macros
    11. On the right side highlight Home(Mail) and click New Group at the bottom
    a. Right click and chose Rename. Enter whatever name you like
    b. Make sure this new folder is highlighted
    12. On the left highlight each Macro (ex: Project1.Project1.Reply.New_Mail) and click Add
    a. Continue until all three Macros are listed in the new folder on the right.
    13. Right click on the first Macro and chose Rename
    a. Pick a pretty icon and rename the Macro to the appropriate function (Reply for Reply, etc)
    b. Optional: Right click the Respond folder and chose Remove to remove the original Reply, Forward, etc.
    c. Continue with the other Macros then hit Ok
    Your new buttons will now appear in the Ribbon and when clicked should give you messages with your Domain B listed as the sender.
    Thank you for this code, works great from the outlook window. In addition to adding these buttons to the ribbon on my home screen I added them to the ribbon inside of an open mail. They work here as well, however, it replies to whichever message I have selected in the main outlook window, not the message I have open. For example, if I were to leave 3 separate emails open, go back to the first one and press reply, it replies to which ever message was last selected in my main outlook window.
    I'd love to have this work from inside mail messages as well. I am trying to push this out to a client but am not sure it will be sufficient as is. Any idea how to make this work from inside mail?
    Thanks again for the code!
