Open Command Window Here - Add or Remove Shift + Right Click
How to Use "Open Command Window Here" Context Menu Item without Shift+ Right Click
This will show you how to add or remove having to press Shift and right clicking on a folder or drive to use the Open Command Window Here from the context menu item for all users in Vista, Windows 7, and Windows 8.
You must me logged in as an administrator to be able to do the steps in this tutorial.
EXAMPLE: Open Command Window Here
NOTE: By default you have to press and hold the Shift key and right click on a folder or drive to click on Open Command Window Here to open a command prompt with the focus at the folder or drive.
Here's How:
1. Shift + Right Click to use "Open Command Window Here"
A) Click/tap on the download button below to download the file below, and go to step 3 below.
Shift+Right_Click_with_Open_Command_Window_Here.reg
Download
2. Right Click Only to use "Open Command Window Here"
Right_Click_Only_with_Open_Command_Window_Here.reg
Download
4. Double click/tap on the downloaded .reg file to merge it.
5. When prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve merging the .reg file.
6. You can now delete the downloaded .reg file if you like.
That's it
Dude that is just awesome Thnx again. :)
Windows 7 Ultimate x64 SP1AMD Athlon II X4 645 quad core6gig DDR3Nvidia geforce GT 630
6gig DDR3
On Board
Samsung LED 19"
ULTRA HD 1080p 1920 x 1080
5 x 2tb
ATA Devices x 2
USB x 5
850 watt something or other forgot name
6 fan in out system with cold air blown through the in
Steelseries
GM.M6800 optical mouse 5 button model
80 gig on a good day 60 to 80 on a bad
not disclosed
not disclosed
My Desktop is in a custom built airflow casing over the case. I still have the power button available etc . but the rest is cool controlled cold air going through the in and theoretically hot air out of the out. But it never gets hot enough for hot air to come out :-P
Right-clicking on a folder, not within it
One should be aware that 'Open command window here' is available when you right-click -ON- a folder name... and not by right-clicking within it. In other words, you cannot be inside a folder and right-click on the window background to get the 'Open command window here' menu item.
However, you -can- do so with the Open Command Windows Here as Administrator registry edit. When you have a folder open, you can right-click on the window background (not on a file), and the pop-up menu will have the 'Open Command Window Here as Administrator' option.
Hello RpD,
When I right click on a empty area within the main folder window, I have a Open command window here option in the context menu. :confused:
Shawn,
Thanks.
Karl
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
You're welcome Karl. :)
Odd
Odd, because I'm not getting that.
I have a new laptop and it seems like that worked on my old one, but the new one won't give me an 'Open command window here' if I right-click a folder background. Old was 32bit, new is 64bit.
Try with shift (hold) + right click to see if it does then.
It will not do this in the "Computer" window, or in a library window. Only in a opened folder's window.
Yes, it will show up with a Shift-hold right-click... on folder window backgrounds, but Shift is not necessary if right-clicking on a folder name. Seems like there must be two different places to set the Shift mode. I don't have to Shift-hold for right-clicking on a folder name... (unless I return the functionality to default behavior).
I updated the REG files in the tutorial. They include those locations as well now. Please give the updated REG files a try to see how they work for you for this now. :)
Yes, indeed... works now... Thanks!
Perfect. :party: You're most welcome.
Awesome Brink!
Thank you.
Windows 7 Home Premium Service Pack 1 32-bit ...AMD C-50 Processor 1.0 Ghz2 GB DDR3 RAM (1.73 usable in System Properties)AMD Radeon HD 6200 series Graphics
Acer Aspire One 722 (AO722)
Windows 7 Home Premium Service Pack 1 32-bit Build 7601
Generic PnP Monitor
1366 x 768 (recommended)
320 GB HDD storage
298.09 GB in Disk Management (REAL)
Built-in on my laptop
External mouse
Installed Windows 7 Service Pack 1 by 9/9/2012
You're welcome Jonathan. :)
.EXE file as Admin
I saw in other Website but it do not Run as Admin so can any of you help how to .EXE as Admin, I did Download the .reg here is what it show
[HKEY_CURRENT_USER\Software\Classes\exefile]
[HKEY_CURRENT_USER\Software\Classes\exefile\shell]
[HKEY_CURRENT_USER\Software\Classes\exefile\shell\cmdhere]
@="Command Prompt .exe file"
[HKEY_CURRENT_USER\Software\Classes\exefile\shell\cmdhere\command]
@="cmd.exe"
Thank
Windows 7 Ultimate x86
This Link you gave me it for 'folder' [Right click on top of the 'folder'] not .exe files so i wanted for on top of the '.exe' file right click Open Command Window Here as Administrator using the ---> .EXE <----
Start Menu,
The "Open Command Windows Here" and "Open Command Windows Here as Administrator" context menus are only for folder locations and not files.
Do you mean Run as administrator instead?
In what version of windows are you saying this is possible? Every single time I do a clean install I always have to get in the registry and make some changes. Personally I like within directory to give non-elevated cmd access only so that if I do want elevated access I just have to hold shift. Now correct me if I'm wrong, but isn't the shift 'extended' shell menu a 64-bit windows thing (WoW64) or does shift give a likewise extended shell menu on 32 bit as well?
I just checked in my windows 8 that I'm booted in at the time of writing this and I am unable to right click a directory in neither the navigation pane or the explorer pane.
You are saying it is by default and that you do not need to access HKCR/Folder/... to add this 'right click a folder w/o shift' to give access to this command?
From my understanding by default:
HKCR/Folder/... has no command access "open this folder in cmd window" upon fresh installation
HKCR/Directory/.. has command access added but only accessed by extended shift menu.
Neither has any Elevated aspect to it.
If I am incorrect could you please fill me in on whatever version of windows you are using and whether or not it is a 32 or 64 bit..
ADDITION: I did fool around with a 3rd program to add some shell context menu features this time, but non were related to CMD, nor would I think that it may have removed something seeing as how simple this is to get a grasp on, with a little practice ;)
Thanks,
Paul
Windows 7 Ultimate x64 SP1Intel Core i5-2.5K (4x) CPU @3.3GHz, Sandy Br...Corsair XMS3 4GB DDR3 @798.1MHz, 1:6, 9-10-10...XFX Radeon HD 6870 Black Edition V2 1GB
Dell - Alienware Aurora R3
Intel Core i5-2.5K (4x) CPU @3.3GHz, Sandy Bridge, 1155 LGA
Alienware 046MHW A00
Corsair XMS3 4GB DDR3 @798.1MHz, 1:6, 9-10-10-25 clocks, 2T
AMD HD (6870 GPU) or Sound Blaster X-Fi Xtream Audio (7.1)
Bad-Ass Acer AL1717 VGA (3x)
3840 x 1024 (1280*3 x 1024)
Western Digital 1TB/64MB HDD @7200 RPM, SATA-II
Seagate Barracuda LP 2TB/32MB HDD @5900 RPM, SATA-II
IDK it's a Spaceship bro..
Color-Changing Alienware Spaceship w/ Active Mood Display™
Liquid Cooling
No flipping idea.. Has PS/2 mouse input like a boss
MS-WMM 4K or Dell PS/2 w/ grime-collecting hamster ball insd
1.80 MB/s DL & 0.50 MB/s UL
Bitdefender Free
VM or Sandboxie Opera Chrome Firefox w/EFF HTTPS Everywhere
Flashing lights and laser beams... Oh and the color-changing Alienware mood display package
