Sticky Notes - Change Default Font
    How to Change the Default Font in Sticky Notes in Windows 7 and Windows 8
    This tutorial will show you how to change the default font in Sticky Notes in Windows 7 and Windows 8.
       Warning
    Copy the StikyNot.exe.mui to your desktop to edit
    Use a resource hacker (I used Restorator 2007). Any resource hacker should do. Open up the StikyNot.exe.mui file from C:\Windows\System32\en-US extracted 3080.xml file.
    Sticky Notes - Change Default Font-restorator-2007-cusersjerrydesktopstikynot.exe.mui.png
    Open it with Notepad++, then highlight Segoe Print.
    Go to Search then Replace.
    A Window will open up, and then type in the font of your choice. Click on Replace All. You will get a window telling you how many times it replaced it. I get 70.
    Sticky Notes - Change Default Font-3.pngSticky Notes - Change Default Font-4.png
    Save the 3080.xml file in Notepad ++. Import/Replace the 3080.xml file back into StikyNot.exe.mui. with a resource hacker, save it. Then go to C:\Windows\System32\en-US\StikyNot.exe.mui take ownership give yourself permission and rename it to StikyNot.exe.bak.mui. Then replace the StikyNot.exe.mui with the one you just edited.
    Jerry
  1. Posts : 960
    Windows 7 Ultimate SP1 - 64 Bit
    Where did you get the .mui from? I could only find the .exe?
    Sticky Notes - Change Default Font-1.pngSticky Notes - Change Default Font-2.png
  2. Posts : 12,120
    Win 7 Pro x64 / Win 10 Pro
    Iam sorry it's in C:\Windows\System32\en-US
    I edited the tutorial already
  3. Posts : 960
    How do I replace the modified 3080.xml back to StikyNot.exe.mui, dragging into Restorator doesn't work. And I can't edit directly from it (copy on Desktop).
  4. Posts : 12,120
    That's how I do it by dragging and dropping back into place I don't know why yours isn't working.
    Jerry
  5. Posts : 1
    Windows 7 Ultimate 64 bit
    Done job. When you drag back the 3080.xml file, be sure to drag it to the folder, not on the space below the html folder. It should be dragged directly into the folder so that the folder is highlighted while you are dragging the xml file.
    And for 64 bit the mui file is located below:
    C:\Windows\winsxs\amd64_microsoft-windows-stickynotes.resources_31bf3856ad364e35_6.1.7600.16385_en-us_567f6e855a658d02
  6. Posts : 223
    Where do I find StickyNot.exe.mui and 3080.xml? I don't see them in System 32. Is it because I have sticky notes open? Do we have to edit anything in syswow64 if you're using 64-bit?
  7. Posts : 2
    Windows 7 Enterprise 64-bit SP1
    Also note that you can open and browse/modify EXE/DLL files in Visual Studio, if you have that. I was able to the same in VS2012.
