Windows 7 Forums Search
Windows 7 - Control Panel Icons View Shortcut - Create
How to Create a Control Panel Shortcut that Always Opens to Icons View in Windows 7
Published by Brink
01-05-2011
Default Control Panel Icons View Shortcut - Create
information   Information
This will show you how to create a Control Panel shortcut that will always open to either Large icons or Small icons view in Windows 7.
You can also Pin to Taskbar or Pin to Start Menu this shortcut, or move where you like for easy use.
Note   Note
The Control Panel Icons View shortcut below will open to either the Large icons or Small icons view as it was last closed as.
EXAMPLE: Control Panel Icons View
Control Panel Icons View Shortcut - Create-cp__large_icons_view.jpgControl Panel Icons View Shortcut - Create-cp__small_icons_view.jpg
OPTION ONE
To Download the "Control Panel Icons View" Shortcut
1. Click on the download button below to download the file below
Control_Panel_Icons_View.zip
download
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Control Panel Icons View shortcut to the desktop.
4. Right click on the Control Panel Icons View shortcut, and click on Properties, General tab, and on the Unblock button. (See screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create the "Control Panel Icons View" Shortcut
1. Right click on a empty area on desktop, and click on New and Shortcut.
2. Type the location below into the location area, and click on the Next button. (see screenshot below)
C:\Windows\explorer.exe shell:::{21EC2020-3AEA-1069-A2DD-08002B30309D}
3. Type Control Panel Icons View for the name, and click on the Finish button. (see screenshot below)
4. Right click on the new Control Panel Icons View shortcut on the Desktop and click on Properties.
5. Click on the Shortcut tab, then click on the Change Icon button. (see screenshot below)
6. In the line under "Look for icons in this file", type in the location below and press Enter. (see screenshot below)
C:\Windows\System32\imageres.dll
7. Select the icon highlighted in blue above and click on OK. (see screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on OK. (see screenshot below)
9. Move the shortcut to where you like for easy use.
Brink's Avatar
Administrator
Tutorial Tools
Comment
 Control Panel Icons View Shortcut - Create problems?
Tutorial Tools
Similar Threads for: Control Panel Icons View Shortcut - Create
Windows 7 Tutorial Category
Control Panel View - Category or Icons Tutorials
How to change icons when seing control panel in Category View? Customization
Control Panel Category View Shortcut - Create Tutorials
Control Panel View General Discussion
