How to Create a "Windows Help and Support" Shortcut
This will show you how to create or download a
Windows Help and Support shortcut in Windows 7 and Vista.
You can also
Pin to Taskbar or
Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
EXAMPLE: Windows Help and Support
OPTION ONE
To Download the "Windows Help and Support" Shortcut
1. Click on the download button below to download the file below
Windows_Help_and_Support.zip
2. Click on Save, and save the .zip file to the desktop.
3. Open the downloaded .zip file and extract the Windows Help and Support shortcut to the desktop
4. Right click on the
Windows Help and Support shortcut, and click on
Properties,
General tab, and on the
Unblock button. (see screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create the "Windows Help and Support" Shortcut
1. Right click on an empty area of your desktop, and click on
New and
Shortcut.
2. Copy and paste either location below into the location area, and click on the
Next button. (see screenshot below)
%windir%\winhlp32.exe
OR
%windir%\explorer.exe shell:::{2559a1f1-21d7-11d4-bdaf-00c04f60b9f0}
3. Type
Windows Help and Support for the name, and click on the
Finish button. (see screenshot below)
NOTE: You can name this anything you would like though. 4. Right click on the new
Windows Help and Support shortcut on the Desktop and click on
Properties.
5. Click on the
Shortcut tab, then click on the
Change Icon button. (see screenshot below)
6. In the line under "Look for icons in this file", type the location below and press
Enter. (see screenshot below)
%SystemRoot%\System32\imageres.dll
7. Select the icon highlighted in blue above and click on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on
OK. (see screenshot below)
9. Move the shortcut to where you like for easy use.
