Windows 7 Forums Search
Windows 7 - Advanced Power Options Shortcut - Create
How to Create a "Advanced Power Options" Shortcut in Windows 7
Published by Brink
01-06-2011
Default Advanced Power Options Shortcut - Create
information   Information
This will show you how to create or download a Advanced Power Options shortcut in Windows 7. This shortcut will open to the advanced settings of your currently selected power plan by default.
You can also Pin to Taskbar or Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
EXAMPLE: Advanced Power Options
OPTION ONE
To Download the "Advanced Power Options" Shortcut
1. Click on the Download button below to download the file below
Advanced_Power_Options.zip
download
2. Click on Save, and save the .zip file to the desktop.
3. Open the downloaded .zip file and extract the Advanced Power Options shortcut to the desktop.
4. Right click on the Advanced Power Options shortcut, and click on Properties, General tab, and on the Unblock button. (see screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create the "Advanced Power Options" Shortcut
1. Right click on a empty area on desktop, and click on New and Shortcut.
2. Type the location below into the location area, and click on the Next button. (see screenshot below)
C:\Windows\System32\control.exe powercfg.cpl,,1
3. Type Advanced Power Options for the name, and click on the Finish button. (see screenshot below)
4. Right click on the new Advanced Power Options shortcut on the Desktop and click on Properties.
5. Click on the Shortcut tab, then click on the Change Icon button. (see screenshot below)
6. In the line under "Look for icons in this file", type the location below and press Enter. (see screenshot below)
%SystemRoot%\System32\powercpl.dll
7. Select the icon highlighted in blue above and click on OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on OK. (see screenshot below)
9. Move the shortcut to where you like for easy use.
Brink's Avatar
Administrator
Tutorial Tools
Comment
 Advanced Power Options Shortcut - Create problems?
Tutorial Tools
Similar Threads for: Advanced Power Options Shortcut - Create
Windows 7 Tutorial Category
How to set Advanced options in Power Options (64 bit Ultimate) Performance & Maintenance
Internet Options Shortcut - Create Tutorials
Advanced User Accounts Shortcut - Create Tutorials
Power Options Shortcut - Create Tutorials
Advanced System Settings Shortcut - Create Tutorials
