Windows 7: Startup Repair Infinite Loop Recovery
29 Jan 2013   #230
Rick
Software and System File problem
On Step 13, my Default, Sam, and Security files are all at the correct 262,000 bytes.
However, my Software and System files are also 262,000 bytes.
How do I correct them to the appropriate amounts?
29 Jan 2013   #231
Brink
64-bit Windows 10 Pro
Hello Rick, and welcome to Seven Forums.
Those are only estimated average sizes in the tutorial to be used only as a guideline. You only have a real issue if they are 0 bytes in size.
29 Jan 2013   #232
Rick
Alright, thank you. I continued the rest of the points from that step, but once I rebooted, it went back into the startup repair loop. I have tried the steps several times thus far. Does anyone have further potential advice?
29 Jan 2013   #233
Rick
I went back and looked at my System bytes, referred to in step 13.
I have an additional SYSTEM.LOG1 that's 262,144 bytes created on the date the problems arose roughly 4 hours after they began. Then below that I have a SYSTEM.LOG2 that is 0 bytes and created back in July of 2009.
30 Jan 2013   #234
Brink
That's fine Rick. It's just for those specific items listed in step 13 and displayed in the screenshot under step 12.
31 Jan 2013   #235
StupidlyClever
Windows 7 Home Premium 64-bit
So, I did the tutorial as you have shown me, and guess what? IT DIDN'T WORK. So, since I have an HP Pavilion dv6 laptop (don't remember the exact model), I can use an Ubuntu Live CD to copy my files to an external drive then reboot and use HP's Recovery Manager to reset the laptop to the factory state, since I don't think there's any other way. But, before I do that, I would just like you to know that I have tried using Bootrec (to no avail), BUT, I haven't fully run chkdsk just yet, so I'm not sure if the disk is actually damaged or not. Should I run chkdsk before I run the factory reset, or should I go on and backup then reset it anyway? (And how do I run it with the parameters again, I forget. :P )
Also, will the HP reset actually work (AKA, actually boot up)? Because I'm a bit skeptical when it comes to fixing my computer.. If not, I could always download the W7 ISO disk from one of the tutorials you provided, I guess.
-StupidlyClever
04 Feb 2013   #236
danprtr
win7
Thanks for the help!
Your solution worked great the first time. Copying a boot drive to another drive should be common enough useage of a partition utility that this issue shouldn't occur, or if it does, it should be referenced by the utility provider.
Messaged Partition Wizard asking that they include a link to your troubleshooting tips, or at least address the "pwnative" error somewhere on their website (search on that error yields nothing currently). Your clear concise write up put an end to hours of confusion so thanks for taking the time!
Dan
07 Feb 2013   #237
kerrykingbirra
hello,
I just tried the solution to the Infinite loop recovery with the prompt, but my operation goes fine until the step 14, in which the laptop try to copy the files for some minutes (with the hard drive light always on),
and then gives this error back: "The request could not be performed because of an I/O device error", and as you can see in the image 4 file(s) were copied.
I tried this more times and I also tried to restart but the problem (as predictable) is not solved.
Can you help me?
Thank you.
Davide
08 Feb 2013   #238
irqthecat
Windows 7 Ultimate 64-bit
Thanks Dzomlija for this. In the years I've been doing support, I never came across a solution for this issue until now. Its always been to reimage with the standard image, or reinstall Windows completely. Today was the first day that I was able to get a client's system back up and running. I had done all the normal Startup Repair tasks both automatically and manually. The system always restarted, not giving me a chance to see the error. Finally I realized that the system was acting just like having a corrupted HAL, and I began searching to see if there were any newer solutions since the last time I had to resolve it. Most searches ended up with just reinstall Windows. I saw yours last night and thought it was worth a try. Amazing result. Thanks again.
13 Feb 2013   #239
bjones99
AMAZING!!!! You guys ROCK!
I woke up to a BSOD after a critical update last night (Thanks, Microsoft...) After banging my head against the wall (proverbially, not actually) I happened across your tutorial. It worked LIKE A CHAMP!!! First time - no problems. As a small business owner who depends on my computer to work perfectly, you guys saved my day. Keep up the good work.
I now hope I am in the right spot to get some help. I am new at this stuff and I couldn't figure out how and where to post my problem. Now I implemented the tutorial about my problem and it worked just great except that whenever I start or restart, the problem is still there and I have to use...
Performance & Maintenance
Startup Repair Infinite Loop Problem
I came home to this infinite loop problem, and well of course I try to look up a tutorial. I reached this point of the stage in the tutorial and didn't know whether I should continue. Now you need to check if you can use the automatic Windows backups to restore your registry: Type CD RegBack...
General Discussion
Infinite Startup Repair Loop - Windows 7 64 bit Laptop
Hello! My problem is easy to explain but not easy to deal with. Yesterday, I'd come home from doing things and turned on my laptop to find a Black Screen with a simple non-blinking mouse cursor on it. (Movable cursor but unable to click anything) So I was confused as to why it'd happened but I...
General Discussion
Im having problems and am stuck in the infinite loop on startup repair. I have followed the tutorial http://www.sevenforums.com/tutorials/139576-startup-repair-infinite-loop-recovery.html i'm getting down to point 10 10) Type DIR and press <ENTER>, and verify that the following files and folders...
Hi, New to the forum here, hope to get some help :confused: Running windows 7 ultimate 32 bit on my computer, which ran fine until recently, where the taskbar will stop responding after I booted my computer, which eventually leads to the entire system freezing. Usually a reboot solves the...
General Discussion
startup repair infinite loop
Hello, My laptop specs: Dell studio 1558 running Windows 7 Home premium (OEM preinstalled) 64-bit with SP1 Core i5 CPU with 4GB RAM windows updates upto-date (enabled) MS Sec Essentials upto-date - scanned 2 hrs before it was down. Today my laptop suddenly switched OFF (by itself) and...
BSOD Help and Support
