Page 56 of 56 FirstFirst ... 46545556
  1. Posts : 4
    windows 7 home premium 64 bit
       #550
    there are 3 hard drives llisted and 1 that has to be the one, because its a 500GB hard drive, but shows 0 Bytes
    when right clicking that drive, and going into properties, i can click on that first button, to check for errors, but then it says, "cant check for errors on the drive, because cant access the drive"
    so copying those commands doesnt work
    if i just type D: in CMD, to jump to that drive it says, "D: CRC error"
    and so happens, when i type that command line "copy D: ... and so on
    running chkdsk D: /f /r right now
    Attached Thumbnails Attached Thumbnails Startup Repair Infinite Loop Recovery-d1.jpg   Startup Repair Infinite Loop Recovery-d2.jpg
  2. Posts : 16,163
    7 X64
       #551
    Yes, it looks like D is the problem.
      My Computers
  3. Posts : 4
       #552
    the chkdsk /f /r command does work, to make the pc boot up again
    but the pc gets that infinite loop problem, almost every day, that means i have to enter the chkdsk /f /r command almost every day
  4. Posts : 16,163
    7 X64
       #553
    Could be a problem with the disk. Safer to get a new disk. They are cheap nowadays.
      My Computers
  5. Posts : 1
    Win 7 64 bit
       #554
    Signed up especially to say thanks to the OP for the first post. After trying multiple system recovery from win 7 iso, rebuild MBR etc, chkdsk, SFC scannow etc etc, using the reg backup files worked. (Win 7 64 bit Samsung laptop)
    Cheers
  6. Posts : 16
    Windows 7 Professional 64
       #555
    That did not work.
