Page 15 of 56 FirstFirst ... 5131415161725 ... LastLast
  1. Posts : 1
    Windows 7 ultimate 32 bit
       #140
    it dint work for me . i don't know what happened . i am really frightened . my exam will start from Monday and i am stuck out here
  2. Posts : 16,161
    7 X64
       #141
    Can you describe the problem ?
    What have you tried to fix it?
    If you tried this tutorial, exactly how far did you get?
    Do you have any repair /recovery media?
      My Computers
  3. Posts : 1
    THANKS!!!!!!!!!!!!!
  4. Posts : 1
    Most helpful tutorial ever used.
    You saved me, jut wanted to show my appreciation!
    Cheers!
  5. Posts : 1
    xp, vista 32,7 32
       #144
    Fantastic-easy to follow even for reg novice
    Can't thank you enough.....
  6. Posts : 1
    Ultimate x64
       #145
    Dude I registered in the forum so to tell you, YOU SAVED MY LIFE EUHAUEUAHE! TKS
  7. Posts : 2
    win 7 32 bit ultimate
       #146
    infinite loop
    Thanks so much for this excellent tutorial :) which saved me lots of time when trying to start win 7 with a newly cloned SSD drive, which norton ghost obviously didn't clone properly. You might consider also listing this tutorial for anyone who cannot get a cloned SSD to boot properly.
    Thanks again
  8. Posts : 1
    Windows 7 64bit
       #147
    Hi, I'm at step 13, and the sizes of my folders are all way off compared to what is described in step 13. Here are the sizes of my folders as shown in Command Prompt:
    DEFAULT - 958464
    SAM - 61440
    SECURITY - 24576
    SOFTWARE - 71118848
    SYSTEM - 19513344
    Ignoring this and pushing on did not get my computer out of the startup repair loop. :[ What might be the problem, here? And how might I fix it?
  9. Posts : 3
    Windows 7 Intel Pentium x64
       #148
    You are simply amazing
    This worked perfect i thought i was going to loose everything and you my legend saved my life. Thank you so much and the images really helped me to follow as i went along . Thank you once again
  10. Posts : 1
    Windows 7 Professional x86
       #149
    Create an account just to show gratitudes.. Thank u so much!! Works like a charm:) just want to know what's the difference between my old system with the system from backups?? Thanks again!
