Page 19 of 56 FirstFirst ... 9171819202129 ... LastLast
  1. Posts : 3
    That's part of the issue. I custom built it for gaming.
  2. Posts : 24
    Windows 7 64bit
       #181
    Hey Brink, i Still havent gotten my laptop to work, but i was going through the steps again and when i got to MD Mybackup it says "A subdirectory or file Mybackup already exists" and that was the first time i did that. So how can check if that is the right thing and should i continue with the steps?
  3. Posts : 72,051
       #182
    Zkhan,
    Step 11 is to create the MD Mybackup folder. Since it says it's already been created, you could just continue on to step 12 and so on. :)
  4. Posts : 24
    Windows 7 64bit
       #183
    Brink,
    The file sizes are not zero but they are very different from what the approximate amount, should i continue
  5. Posts : 72,051
       #184
    Zkhan,
    The important part is that they are not zero, so you should be good to go to continue the steps. :)
  6. Posts : 24
    Windows 7 64bit
       #185
    Brink,
    It didnt work, i restarted it and it went back to the startup repair
  7. Posts : 72,051
       #186
    You may need to reinstall.
  8. Posts : 24
    Windows 7 64bit
       #187
    Hey Brink,
    The peppermint 3 backup, if i used my external hard drive would it be fine because i have a lot of things i want to take off of it. Wondering because in the peppermint 3 page it says the usb gets formatted so would that ruin my external hard drive
  9. Posts : 72,051
       #188
    The only thing that would be formatted would be the USB flash drive that you use to create the Peppermint 3 on. Otherwise, you would just be copying and pasting to the external drive. :)
  10. Posts : 24
    Windows 7 64bit
       #189
    So I was thinking of having a usb with the program, and then the external hard drive separate and just move the files there, once again thanks for the help
