Windows 7: Startup Programs - Change
How to Change, Add, or Remove Startup Programs in Windows 7
Published by Brink
06 Jan 2009
information   Information
This will show you how to either add, remove, enable, or disable a startup program in Windows 7.
Note   Note
You can also view the startup logs in Event Viewer (C:\Windows\system32\eventvwr.msc) under Applications and Services Logs, Microsoft, Windows, Diagnostics-Performance, and Operational. The logs will be in the middle to show you what ran at startup, how long it took, and more.
warning   Warning
User Account Control prevents programs that require elevated (run as administrator) permission or an administrator password from running automatically when Windows 7 starts. If a program is blocked, you'll see a message in the notification area that says some startup programs need permission to run. You can then right click on the notification area message and either select to run the blocked program by giving UAC permission, remove the blocked program from the startup program list, or ignore the notification and not run the program.
Startup Programs - Change METHOD ONE Startup Programs - Change
Through the Program Itself
NOTE: Some programs may have a setting in them to allow it to run at startup or not. You will need to consult the program's documentations on how to do this specifically for their program if it is available for that program.
1. Open the program's settings menu.
2. To Add the Program to Startup
A) Select the program's Run at startup type option.
3. To Remove the Program from Startup
A) Unselect the program's Run at startup type option.
Startup Programs - Change METHOD TWO Startup Programs - Change
Through the Startup Folder
NOTE: You can add or remove shortcuts to programs or files from the Startup folder to have them run or open at the startup of Windows 7.
1. Right click on the exe file of the program you want to run at startup, or file to open at startup, and click on Create Shortcut.
NOTE: This is the shortcut that you will add to the Startup folder in either Option One or Option Two below. Skip this step if you are only removing a shortcut from the Startup folder.
A) Do either OPTION ONE "Current User" or OPTION TWO "All Users" below for what you want.
Startup Programs - Change OPTION ONE Startup Programs - Change
For Current Single User Only
NOTE: The single (current) user Startup folder is a hidden system folder located at:
C:\Users\(User-Name)\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
2. Open the Start Menu, click on All Programs, right click on the Startup folder, click on Open or Explore, and go to step 4 below. (See screenshot below)
OR
3. In the Start Menu search line, type shell:startup, press Enter, and go to step 4 below. (See screenshot below)
4. Do step 5 or 6 below for what you would like to do.
5. To Add a Startup Program or File Shortcut
A) Drag the shortcut created from step 1 to inside the Startup folder and drop it. (See screenshot below)
6. To Remove a Startup Program or File Shortcut
A) Right click on the shortcut in the Startup folder and click on Delete. (See screenshot above)
7. Close the Startup folder when done. (See screenshot below step 5A)
Startup Programs - Change OPTION TWO Startup Programs - Change
For All Users
NOTE: The all users Startup folder is a hidden system folder located at:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
2. Open the Start Menu, click on All Programs, right click on the Startup folder, click on Open All Users or Explore All Users, and go to step 4 below. (See screenshot below)
OR
3.
In the Start Menu search line, type shell:common startup, press Enter, and go to step 4 below.
6. Close the Startup folder when done. (See screenshot below step 4A)
Startup Programs - Change METHOD THREE Startup Programs - Change
Through System Configuration (msconfig)
NOTE: Using the Selective Startup option in System Configuration (msconfig), you can enable or disable startup programs. You will need to be logged into an administator account, or provide the administrator password to open System Configuration.
WARNING: It would be best to also check the registry entries in METHOD FOUR below as well, since msconfig may not always show all startup programs.
1. Open the Start Menu, type msconfig in the search box, press Enter, and go to step 3 below. (See screenshot below)
OR
2. Open the Control Panel (icons view) and click on the Administrative Tools icon, then click on System Configuration. Close the Control Panel and Administrative Tools windows.
3. If prompted, click on Continue for the UAC prompt, or type in the administrator's password.
4. Click on the Startup tab. (See screenshot below)
Tip   Tip
If you look under the Location column for the Start Item, you will see the registry location for it that you can use to remove the startup item using METHOD FOUR below instead.
5. To Disable a Startup Program
A) Select a listed startup program and uncheck it. (See screenshot above)
B) Repeat to disable anymore listed startup programs.
6. To Enable a Startup Program
A) Select a listed startup program and check it. (See screenshot below step 4)
B) Repeat to enable anymore listed startup programs.
7. To Disable All Listed Startup Programs
A) Click on the Disable all button. (See screenshot below step 4)
B) Go to step 9.
8. To Enable All Listed Startup Programs
A) Click on the Enable all button. (See screenshot below step 4)
9. Click on Apply. (See screenshot below step 4)
10. Click on the Boot tab, then check the Make all boot settings permanent box and click on OK. (See screenshot below)
11. Click on Yes. (See screenshot below)
12. Click on the Restart button to apply. (See screenshot below)
WARNING: This will restart your computer immediately. Save and close anything that you are working on first.
Startup Programs - Change METHOD FOUR Startup Programs - Change
Manually in Registry Editor
NOTE: This will allow you to remove a startup program for either the current single user or all users. If you wanted to add a startup program, then METHOD TWO above would be a safer and easier way to do so.
1. Open the Start Menu.
2. In the search line, type regedit and press Enter. (See screenshot below)
3. For "Current User" Only Locations
A) In regedit, go to: (See screenshots below)
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
AND
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce
4. For "All Users" Locations
For 32-bit and 64-bit Windows 7:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
AND
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
AND (If added by Group Policy)
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run
AND
For 64-bit Windows 7 only:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run
AND
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\RunOnce
5. In the right pane of Run and/or RunOnce, right click on the startup program you want to remove and click on Delete. (See screenshots above)
NOTE: RunOnce is only to run the program once for the next time that Windows 7 starts up. Run is to run the program everytime that Windows 7 starts up.
6. Click on Yes to confirm deletion.
7. When done, close regedit.
Startup Programs - Change METHOD FIVE Startup Programs - Change
Using CCleaner
1. If you have not already, download and install the free program CCleaner.
2. Open CCleaner, and click on the Tools icon (left side) and on the Startup button. (See screenshot below)
3. Select a startup item, then either enable, disable, or delete it from the Vista startup programs list. (See screenshot above)
Startup Programs - Change METHOD SIX Startup Programs - Change
Through Task Scheduler
Note   Note
By default, you cannot run a elevated (Run as administrator) program that requires UAC permission at startup using the normal Windows 7 startup programs above.
For a Administrator User Account:
You can have Run as administrator (elevated) programs run at startup for a administrator account by running it in a startup task in Task Scheduler.
For a Standard User Account:
You will not be able to run elevated programs at startup for a standard user account though. Only unelevated programs (ex: Notepad).
1. For how to create a startup task, see:
How to Create a Task to Run a Program at Startup and Log On in Windows 7
06 Jan 2009   #1
darkassain
run once isnt that that it only runs on next reboot???
thats how i remember....
im think it should be stated
just a thought...
if im wrong then and its changed let me know...
06 Jan 2009   #2
Brink
64-bit Windows 10 Pro
Yep, you are correct Darkassain. Note added.
Thank you,
14 Jan 2009   #3
Dinesh
Windows® 8 Pro (64-bit)
Also through Windows defender...
14 Jan 2009   #4
Brink
Hi Dinesh,
Sorry, but startup programs has been removed from Windows Defender in Windows 7. It is now strictly a anti-malware program.
14 Jan 2009   #5
Coldout
I'm using the registry to run SpeedFan at startup, but I have to Disable UAC as the driver isn't signed.
Is there a way to bypass UAC for this, without the need to disable UAC? I did post feedback to MS saying that it would be nice if UAC had User overide feature, so we could allow some programs we need.
14 Jan 2009   #6
Brink
Coldout,
You might see if creating a task in Task Scheduler to run SpeedFan at startup instead may work better for you.
Task Scheduler - Wake Up Computer - Vista Forums
15 Jan 2009   #7
Coldout
Nice one thanks.
I have it running at start now. Just the icon not showing.
Seems to be running ok, when I use task manager - show processes from all users. It is there, though cannot see CPU temps or change settings via task bar Icon.
This is a lot better than having to run it manually every time I boot. And I can leave UAC on now too.
Thanks again!
15 Jan 2009   #8
Brink
You're welcome Coldout.
You might see if using Compatibility Mode with Vista selected on the SpeedFan exe file may allow the icon to show.
12 Jul 2009   #9
Sope
Windows 7 64-bit
Quote   Quote: Originally Posted by Brink View Post
Coldout,
I've also followed this advice and have Speedfan opening successfully on startup, but there's still a problem - I would like it to open in a minimized state. I know this can be done by customizing a shortcut but I can't see a way to achieve this using the Task Scheduler.
Any advice appreciated.
UPDATE: After taking another look at Speedfan's settings I found the option to force it to always start minimized - sorry for being a dope!
How to change the order of startup programs
When I got a Win7 computer from Dell, McAfee was already installed. How can I change the sequence of the booting order of startup programs. For example, I would like to place McAfee proram at the end of the booting sequence for the startup programs. hummer
General Discussion
Startup programs help
Hi, I have just had to purchase a new PC and went with an off the shelf Lenovo 330 for speed of purchase and I need a little help. I am not a very experienced user and I am looking for help to decide which programs I can disable/delay at startup. I have looked at the msconfig startup tab but...
Performance & Maintenance
Startup programs
I have just taken delivery of a new computer running Windows 7 64 bit. I have copied short cuts to Skype and to Birthday reminder to the Startup folder but neither of these program s will start at boot up. Have seen varuious similar reports of the same problem on the internet and have tried some...
General Discussion
What startup programs are necessary?
hello again. I can see that the bluetooth (Btvstack.exe & AthBtTray.exe) starts up with the pc. is it necessary? next thing is the USB3 (nusb3mon.exe) and many other. so i am asking what are the necessary startup progams?
Startup programs not opening during startup
I am running Windows 7 Ultimate 64-bit. I have CPU-Z, Hardware Monitor Pro and Resource Monitor shortcuts in the startup folder. If I go to MSCONFIG I can see that the items are there to be started during startup. What am I doing wrong that will not allow these programs to start up?
General Discussion
Why is there no Control Panel/Programs/Change Startup..
..Programs anymore? I liked how Vista had that feature. Now it seems the only way to disable startup programs is by 'msconfig' right?
Software
