How to Create a Taskbar Properties Shortcut in Windows 7
This will show you how to download or create a
Taskbar Properties shortcut in Windows 7.
You can also
Pin to Taskbar or
Pin to Start Menu this shortcut, or move where you like for easy use.
EXAMPLE: Taskbar Properties
OPTION ONE
To Download a "Taskbar Properties" Shortcut
1. Click on the Download button below to download the file below
Taskbar_Properties_Shortcut.zip
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Taskbar Properties shortcut to the desktop
4. Right click on the
Taskbar Properties shortcut, and click on
Properties,
General tab, and on the
Unblock button. (see screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create a "Taskbar Properties" Shortcut
1. Right click on a empty area on desktop, and click on
New and
Shortcut.
2. Copy and paste the location below into the location area, and click on the
Next button. (see screenshot below)
%SystemRoot%\System32\rundll32.exe shell32.dll,Options_RunDLL 1
3. Type
Taskbar Properties for the name, and click on the
Finish button. (see screenshot below)
NOTE: You can name this anything you would like though. 4. Right click on the new
Taskbar Properties shortcut on the Desktop and click on
Properties.
5. Click on the
Shortcut tab, then click on the
Change Icon button. (see screenshot below)
6. In the line under "Look for icons in this file", copy and paste in the location below and press
Enter. (see screenshot below)
%SystemRoot%\System32\imageres.dll
7. Select the icon highlighted in blue above and click on
OK. (see screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on
OK. (see screenshot below)
9. Move the shortcut to where you like for easy use.
