Windows 7: Partition / Extended : Logical Drives
25 Dec 2012   #80
YousefDxb
Ultimate Win7 32bit
Quote   Quote: Originally Posted by YousefDxb View Post
Dear all,
Please advice how to put back a partition into primary partition. I need to have it all back to disk 0
Quote   Quote: Originally Posted by Brink View Post
Hello Yousef, and welcome to Seven Forums.
Please go ahead and post back with a screenshot showing the full layout of your Disk Management window first. This way we will be able to give you an accurate answer.
Dear Brink, Thank you for immediate reply...attached screen shot.
Partition / Extended : Logical Drives-disk-mgnt..png
25 Dec 2012   #81
whs
Microsoft MVP
And what exactly do you want to do ??
25 Dec 2012   #82
Brink
64-bit Windows 10 Pro
Yousef,
You'll need to use a free program like MiniTool Partition Wizard Free to be able to extend the Win7-new (192.81 GB) partition into the 2.50 GB partition.
The instructions at the program's links below can help show you how to.
First delete the 2.50 GB partition:
How to Delete Partition with partition manager? Partition Wizard Help
Next, extend Win7-new (192.81 GB) partition into the 2.50 GB partition.
Extend partition with partition magic software ? MiniTool Partition Wizard.
Hope this helps.
26 Dec 2012   #83
YousefDxb
Ultimate Win7 32bit
Brinks, Thanks for your clear information.
26 Dec 2012   #84
Brink
You're welcome Yousef. Glad it was able to help.
02 Mar 2013   #85
emoallem
Oklahoma
Oh Thank you! This MiniTool Partition Wizard is excellent! I downloaded it and it fixed all my partitioning problems. I made 4 huge partitions immediately without an problem. I have been spending my whole day trying every method I read in forums but none of them work. but this Partition Wizard solved all of them at once. It is incredible. I donated money to their website immediately. Since this software solved my problem in 10 minutes while I have been searching on Microsoft.com, using their live chat support,
applying hundreds of other solutions in forums for hours. Thank you very much for introducing this software. I love it. Thank you!
04 Mar 2013   #86
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by emoallem View Post
Hello emoallem, welcome to Seven Forums; glad we could be a help.
04 Apr 2013   #87
NateR999
Hi
First off sorry for reawakening the thread, but I really need help.
Ok so i have downloaded all the necissary things including PWBD ISO file but when I attempt to use Windows 7 USB/DVD Download Tool to create a bootable USB i get an error saying that I have an invalid ISO file?
Please see the Screenshot
Partition / Extended : Logical Drives-invalid-iso.png
04 Apr 2013   #88
whs
Microsoft MVP
You have the CD version. For the USB version you need PW Pro. I am sure it will burn to CD.
05 Apr 2013   #89
NateR999
yes but thats not the main issue..because I thought of that but u select the ISO file before u select the medium(CD/USB) so it gives me that error before I even get a chance to choose USB...
Is there something wrong with the file? or maybe I need to use a different application to create the bootable cd from the ISO
Can I install Win XP on a 4th logical/extended partition?
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html (Guide) I have Win 7 installed (64 bit) on a Dell Laptop w/ 3 primary partitions 1. OEM Partition- 102MB 2. System, Active (Dell Recovery)- 14GB 3. Boot, Page file, Crash dump (Win 7) I will create a 4th...
Installation & Setup
Here's a new one. Partition / Extended : Logical Drives
i cant convert extended partition to logical partitiion..
hi frds,,,, pls help me.. i installed windows 7 on primary partition with 19gb disk space, while in D disk having 39gb disk space cannot be allocated from its unallocated space mode, with extended type partition... pls any1 solve dis prob...
How do I make an extended partition with logical
I am totally confused as to the difference between "partition" and "Volume" I want to partition the C: drive to give an Extended partition with 2 logical partitions to remove Data from the C: and put MY installed programs. Do I have to use 3rd party software for this?
General Discussion
Difference between Primary, Extended, Logical Partition
Windows 7 is coming pre-installed on my new PC from Dell. It has two 500GB HDDs. I want to partition the first drive into just a couple of partitions. I guess I will have to shrink the main partition to about 100GB for the OS and apps. But my question is: that partition with the OS and apps...
General Discussion
how to create an extended partition with logical drives
Hi everyone, Just new here, i am right now installing my new-built PC with Windows 7 Enterprise. Unfortunately, i have already some problems. My hard drive is a 1 TB WD and on setup i made a primary partition of 50 GB for win7. I thought to partition the rest afterwards and there is the...
