Partition / Extended : Logical Drives
Page 9 of 12 FirstFirst ... 7891011 ... LastLast
  1. Posts : 3
    Ultimate Win7 32bit
       #80
    YousefDxb said:
    Dear all,
    Please advice how to put back a partition into primary partition. I need to have it all back to disk 0
    Brink said:
    Hello Yousef, and welcome to Seven Forums.
    Please go ahead and post back with a screenshot showing the full layout of your Disk Management window first. This way we will be able to give you an accurate answer. :)
    Dear Brink, Thank you for immediate reply...attached screen shot.
    Attached Thumbnails Attached Thumbnails Partition / Extended : Logical Drives-disk-mgnt..png
  2. whs
       #81
    And what exactly do you want to do ??
  3. Posts : 72,051
       #82
    Yousef,
    You'll need to use a free program like MiniTool Partition Wizard Free to be able to extend the Win7-new (192.81 GB) partition into the 2.50 GB partition.
    The instructions at the program's links below can help show you how to.
    First delete the 2.50 GB partition:
    How to Delete Partition with partition manager? Partition Wizard Help
    Next, extend Win7-new (192.81 GB) partition into the 2.50 GB partition.
    Extend partition with partition magic software ? MiniTool Partition Wizard.
    Hope this helps. :)
  4. Posts : 3
    Ultimate Win7 32bit
       #83
    Brinks, Thanks for your clear information.
  5. Posts : 72,051
       #84
    You're welcome Yousef. Glad it was able to help. :)
  6. Posts : 1
    Oklahoma
       #85
    Oh Thank you! This MiniTool Partition Wizard is excellent! I downloaded it and it fixed all my partitioning problems. I made 4 huge partitions immediately without an problem. I have been spending my whole day trying every method I read in forums but none of them work. but this Partition Wizard solved all of them at once. It is incredible. I donated money to their website immediately. Since this software solved my problem in 10 minutes while I have been searching on Microsoft.com, using their live chat support,
    applying hundreds of other solutions in forums for hours. Thank you very much for introducing this software. I love it. Thank you!
  7. Posts : 22,814
    W 7 64-bit Ultimate
       #86
    Hello emoallem, welcome to Seven Forums; glad we could be a help.
  8. Posts : 6
    Hi
    First off sorry for reawakening the thread, but I really need help.
    Ok so i have downloaded all the necissary things including PWBD ISO file but when I attempt to use Windows 7 USB/DVD Download Tool to create a bootable USB i get an error saying that I have an invalid ISO file?
    Please see the Screenshot
    Attached Thumbnails Attached Thumbnails Partition / Extended : Logical Drives-invalid-iso.png
  9. whs
       #88
    You have the CD version. For the USB version you need PW Pro. I am sure it will burn to CD.
  10. Posts : 6
    yes but thats not the main issue..because I thought of that but u select the ISO file before u select the medium(CD/USB) so it gives me that error before I even get a chance to choose USB...
    Is there something wrong with the file? or maybe I need to use a different application to create the bootable cd from the ISO
