Windows 7: SSD - Install and Transfer the Operating System
23 Feb 2013   #420
mjf
Windows 7x64 Home Premium SP1
As WHS says it is up to you. I have system reserved on 2 PCs and no system reserved on a 3rd. It doesn't matter and my decision was quite whimsical since I don't use bitlocker.
Before you assume "MS know best" the system reserved at 100MB was not a good choice. Mine are 200MB for good reason. If you use Windows inbuilt imaging and a 100MB system reserved some users have run into trouble (shadow storage copy issues)
Backup Error 0x81000019 - Fix
25 Feb 2013   #421
Expansion
Windows 7 Pro x64
Quote   Quote: Originally Posted by Britton30 View Post
I don't use the Reserved Partition and have no trouble. As for MS having a good reason, they are the people who brought us Windows ME, IE7, and Win 8.
Macrium has the option to verify an image too, bit by bit. Better than the XPired ideas with DOS.
Ok, I have decided to go with Macrium.
Can you guide me on how to proceed?
25 Feb 2013   #422
whs
Microsoft MVP
Quote   Quote: Originally Posted by Expansion View Post
Start with this tutorial: Imaging with free Macrium
If you have questions, let us know.
24 Mar 2013   #423
COMPUTIAC
Windows 8.1.1 64bit
Used Paragon Migrate OS to SSD;
How do I turn off Hibernate ?
The Win7 is still on the HDD, should I just wipe it ?
Any advice ?
24 Mar 2013   #424
whs
Microsoft MVP
Quote   Quote: Originally Posted by COMPUTIAC View Post
Any advice ?
The command to get rid of the hibernation file is powercfg -h off
If the SSD system works well, you can get rid of the OS on the HDD - just reformat the partition and also the 100MB system partition (if any). But make first sure that the SSD does not depend on it. Post a screenshot of your Disk Management. Use the space to make images from the SSD.
24 Mar 2013   #425
COMPUTIAC
Windows 8.1.1 64bit
WHS, thank's for the quick reply.
Where do I use the command ?
I don't see how the SSD is dependant on it as the HHD is disconnected now.
I use a external HDD for back-ups if this is what you are reffering to.
24 Mar 2013   #426
whs
Microsoft MVP
The SSD looks OK. No need for the system on the HDD any more
The command is for Command Prompt. Go to Start > All Programs > Accessories > right click on Command Prompt > Run as Admin. Then you get a small black window where you can enter the powercfg command. Then press Enter.
24 Mar 2013   #427
COMPUTIAC
Windows 8.1.1 64bit
WHS, command did its job.
I can do a quick format on the HDD ?
Is there any part of the OS I should transfer to the HDD ?
Maybe not the OS itself but some user folders ?
24 Mar 2013   #428
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
quick format will work. Saving some user data will be a start as a backup.
24 Mar 2013   #429
whs
Microsoft MVP
I always keep my user folders on the HDDs. Do the following:
1. On the HDD, define folders for Documents, Music, Videos, Music
2. Right click on those folders and INCLUDE them into the approriate library
3. Copy your own folders (not the main folders like My Documents) to these folders on the HDD
4. Done - in the future, move your stuff always into the HDD folders
5. The main folders on the SSD will be used by some programs (especially the Documents folder). That's why they have to stay there. But the amount of data that those programs put into there is minimal.
PS, keep all OS files on the SSD. And as Gary says, always use quick format.
I can not install no operating system
Hello ! I tried to install a myriad of DVDs or USB keys for Widows 7 that in the pc of my friends all go perfectly, in my case initially l 'installation goes, but then I get the following message: "FILE OR DIRECTORY d: DAMAGED AND NOT READABLE. RUN THE UTILITY 'CHKDSK "
Installation & Setup
After new Win 7 install - msg: Operating System Not Found
Hi first time on the forum so if I don't give all the necessary info. let me know and I'll provide what I can. System : eMachines G640 Disk Drive : WD3200BEVT O/S : Win 7 Home Premium x64 (from heidoc.net) Original disk drive failed with read errors so was replaced with above (like for like)....
Operating system install on external dock
Hey there everyone I am having a little trouble trying to figure out how to install an operating system on a hard drive that is externally docked on my multi-function HDD Dock that is connected usb. The hard drive is currently locked out from a virus. Any ideas? Thanks!
Missing Operating System after bad HDD driver install
Hi everybody...I have a Dell Inspiron15r model N5010 that I was trying to upgrade to windows 8 Pro when I went and downloaded many of the drivers from Dell so that I had all the latest and greatest. in my quest for quickness, I accidentally installed a driver for a HD that was listed when I meant...
Computer won't install (seemingly) any operating system.
I'm going to try and keep this as concise as possible. I was working on an older custom built PC for my girlfriend's father. He said that it had been sitting for quite a while and didn't remember what was wrong with it. I offered to take a look and that puts me in my present predicament. ...
General Discussion
How to install another operating system
I have a Windows 7 Computer but I want to put Ubuntu Linux on a separate partition. I can't figure out how to do that. I already have the iso and have a new partition. Please help.
