WIM File - Extract and Modify
Page 5 of 5 FirstFirst ... 345
  1. Posts : 6
    That is Amazing!! It's actually starting up....but before it did..it brought up the select which one you want to boot...and the choices were Microsoft Windows Vista & Windows Vista....will that change after it installs Windows??? or should i just edit the Boot.ini???? Thanks a ton!!!!
  2. Posts : 16,174
    7 X64
       #41
    It's been so long I had forgotten about this thread.
    Glad it worked for you.
    If you end up with 2 boot menu entries - you should be able to remove one easily enough - under the Boot tab in msconfig.exe
      My Computers
  3. Posts : 15
    Windows 7 Ultimate x86
       #42
    I have all Windows 7 editions on my DVD. When I have mounted install.wim (and I have only one, 4 gigabytes), I see a complete x86 structure. But there is NOTHING AT ALL related to x64 edition. No SysWow64 folder, no 64-bit DLLs, nothing. I have searched everything. Where the heck could it hide 64-bit files?
    EDIT:
    Got it... I should have selected which image to modify. That seems to suggest that I have to modify all 9 images. What a big amount of pain in the @$$. Unless maybe modifying highest in the hierarchy (x86 Ultimate and x64 Ultimate) is enough. I sure hope so.
  4. Posts : 16,174
    7 X64
       #43
    You will have to modify every image- if you want them all to include whatever mods you are doing.
    No way round that.
    I don't know why you would want to.
    You could just modify the image you are going to use ( the one you have the product key for ).
      My Computers
