How to Repair Windows 7 System Files with System File Checker
The sfc /scannow command (System File Checker) scans the integrity of all protected Windows 7 system files and replaces incorrect corrupted, changed/modified, or damaged versions with the correct versions if possible.
   Tip
If you get the Windows Resource Protection Could Not Start the Repair Service error when trying to run SFC, then make sure that the Windows Modules Installer service is enabled, click on Start, and set to Manual.
Services - Start or Disable
OR
Copy and paste the command below in the elevated command prompt, and press Enter. After the Windows Modules Installer service has started, try running the SFC command again
net start trustedinstaller
The KB3022345, KB3035583, and KB3068708 updates will cause SFC to give you a false mismatch message in SFC for files related to these updates.
You can safely ignore these results in your SFC details since it will not affect SFC from being able to repair other system files.
   Warning
Be aware that if you have modified your system files as in theming explorer/system files, running sfc /scannow will revert the system files such as explorer.exe back to it's default state. Make the appropriate backups of your system files that you have modified for theming if you wish to save them before running sfc /scannow.
:note: For the updated Windows 10 tutorial, please see - SFC Command - Run in Windows 10 - Windows 10 Tutorials
CONTENTS:
  • Option One: To Run the SFC /SCANNOW Command at Boot
  • Option Two: To Run the SFC /SCANNOW Command in Windows 7
  • Option Three: How to See and Read Only the "SFC" Scan Results from the CBS.LOG
OPTION ONE
1. For how, see METHOD TWO at this link: SFC /SCANNOW : Run in Command Prompt at Boot
Using OPTION TWO below is recommended if able.
If you would like to get help with your SFC issue, then be sure to upload and attach your sfcdetails.txt file from OPTION THREE below in your post.
OPTION TWO
1. Open an elevated command prompt or an elevated PowerShell, and do step 2 or 3 below for what type of scan you would like to run.
2. To Scan and Repair System Files
NOTE: Scans the integrity of all protected system files and repairs the system files if needed. Please see red WARNING box at the top of this tutorial.
A) In the elevated command prompt, type sfc /scannow, press Enter, and go to step 4 below. (see screenshot below)
NOTE: This may take a little bit to finish.
3. To Only Verify if the System Files are Corrupted
NOTE: Scans and only verifies the integrity of all proteced system files only. This command will not change your system files as in the red WARNING box at the top of this tutorial.
A) In the elevated command prompt, type sfc /verifyonly, press Enter, and go to step 4 below.
4. When the scan is complete, hopefully you will see all is ok like the screenshot below.
  • If SFC could not fix something, then run the command again to see if it may be able to the next time. Sometimes it may take running the sfc /scannow command 3 or more times to completely fix everything that it's able to.
  • If not, then download and run the 32-bit (x86) or 64-bit (x64) System Update Readiness Tool for your same installed 32-bit or 64-bit Windows 7, restart the PC afterwards, and try the sfc /scannow command again.
  • If still not, then try using OPTION ONE above to run the sfc /scannow command at boot.
  • If still not, then you can attempt to run a System Restore using a restore point dated before the bad file occured to fix it. You may need to repeat doing a System Restore until you find a older restore point that may work.
  • If still not, then you can use the steps in the TIP box in the OPTION THREE section below to manually replace the files that SFC could not fix if there are not to many fix.
  • If there are to many files to manually fix, or you prefer not to use OPTION THREE below, then you could do a repair install without losing anything.
5. When done, close the elevated command prompt.
OPTION THREE
When SFC runs, it logs it's actions into the C:\Windows\Logs\CBS\CBS.log. The steps in this option will show you how to see only the specific SFC entries with the [SR] tags in this CBS.log. This can be helpful to show you what files SFC could not fix automatically if you wanted to try and manually replace them.
1. Open an "elevated command prompt" (right click -> Run as administrator).
2. In the elevated command prompt, copy and paste the command below, and press Enter. (See screenshot below)
NOTE: This will place a sfcdetails.txt file on your desktop with only the SFC scan result details from the CBS.LOG in it.
findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt"
3. Close the elevated command prompt.
4. Open the sfcdetails.txt file on your desktop to see the SFC scan details in the CBS.LOG.
5. You can safely delete the sfcdetails.txt file afterwards if you like.
   Tip
If you need to replace a corrupted system file that SFC cannot fix, then this will show you how to by extracting a new copy directly from your Windows 7 installation DVD.
Extract Files from Windows 7 Installation DVD
It's still saying the same error. I copied the CBS.log text file to my desktop, and its still giving an error.
Windows 10 Home 64-bitAMD E-350 Zacate 40nm Technology4 GB DDR3 Memory1909MB ATI AMD Radeon HD
Acer 5250-0450
Acer HMA51-BZ (Socket FT1)
4 GB DDR3 Memory
Conexant High Definition Audio
Generic PnP Monitor (1366x768@60Hz)
320 GB HDD
ONN Wireless Mouse
Norton Internet Security Online
Microsoft Edge, Internet Explorer 11, and Google Chrome
Other Computers:
Laptop: Acer Aspire 5749 Series
Desktop: Acer Aspire XC603G Series
In that case ZIP the CBS.log on your desktop, and upload the ZIP file here. I'll be happy to take a look at it. :)
Sorry, Brink. I went out of town with the family tonight, and we are just now getting in. But, below is ZIPPED Folder with the CBS log in it.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Jesse,
You mistakenly zipped a shortcut to the CBS.log file instead of the actual log file.
After you copy and paste the C:\Windows\CBS\CBS.log file to your desktop, zip that, then upload it. :)
I don't understand! Either that, or what I am doing is not working.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Whenever I try to do that, it says Compressed (zipped) Folders Error that then says File not found or no read permission.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
It sounds like you are trying to ZIP it directly in your "C:\Windows\CBS" folder. That won't work if so.
You will have to copy the CBS.log file from the CBS folder to your desktop first. Afterwards, ZIP the file on your desktop instead.
Brink, so what do I do now?
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Just what I posted above to ZIP the correct file, and upload it. :)
I tried that, and it didn't work.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
What didn't work?
You should be able to copy the CBS.log file to your desktop. The first time, you just made a mistake and created a shortcut of it instead of copying and pasting it to your desktop.
I think I am doing something wrong. Maybe, I need to post a screenshot of what I am doing.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
I am trying to upload it, but it's synced with my Adobe Creative Cloud. Therefore, I think that's causing it a while to upload.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Brink, it's not wanting to upload. It's taking it too long to upload.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Did you ZIP it?
Yes, it's zipped. But, for some reason, it's having trouble uploading. I have checked it, and it's not a shortcut file. It's a text document file.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
It will only upload a shortcut document.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
It says CBS.zip: Your file of 15.16 MB bytes exceeds the forum's limit of 8.00 MB for this filetype.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
These are the screenshots of the CBS log.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Maxie and Brink, see if you all can read this.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
