Page 34 of 99 FirstFirst ... 24323334353644 ... LastLast
  1. Posts : 54
       #330
    SFC
    Brink said:
    What is the "service line" that you removed?
    Do you mean that you deleted the "Windows Defender Service"?
    Avie said:
    Yes I did remove W D service line. However I ran a Karpersky scan and it showed Windows Defender. That would the reason WSE will not turn on.
    I still have more than one connection is it seems. IE Firefox default profile is located in Users>Ali>ALLDATA>Roaming. And also in Users>Ali>ALLDATA>local with another profile. Does that make sense?
  2. Posts : 72,046
       #331
    If you actually deleted the Windows Defender service in the Services window, then that would be why MSE and Windows Defender is no longer working. That service is required for them to run.
    You could try and fix this by doing a system restore using a restore point dated before you deleted the service. If you do not have a restore point available before this happended, then you may need to reinstall Windows 7 to be able to fix this.
  3. Posts : 54
       #332
    SFC
    I read that was the way to get rid of Windows Defender rather than disabling. I think it was awhile back. I will try. Thank you!!!
  4. Posts : 72,046
       #333
    You're welcome. I hope you have a restore point available for back then.
  5. Posts : 54
       #334
    Rstore a faillure
    The Win Defender could not read directions and had a error code 2. WSE cannot turn on. Time for reinstall. I fear. Just so fruitless.
  6. Posts : 72,046
       #335
    Yeah, deleting services like that can cause some serious issues.
  7. Posts : 54
       #336
    Services done
    I really did read to do that. Made sense at the time. I'll get it done. Thanks to your tutorial on the subject. Bless you.
  8. Posts : 72,046
       #337
    Eh, don't sweat it. We all make mistakes. :)
  9. Posts : 54
       #338
    Practice makes perfect!
  10. Posts : 2
    windows 7 home premium 64bit
       #339
    can't get an elevated command prompt
    I am following your instruction by going to start, all programs, accessories, right clicking command prompt and selecting "run as administrator". It takes me to a regular command prompt..C:\Users\Daniel>...according to your instructions...is should read...C:\Windows\system32...what am I doing wrong?
