Page 66 of 99 FirstFirst ... 56646566676876 ... LastLast
  1. Posts : 9
    Windows 7 Pro 64-bit
       #650
    Brink said:
    Check in your Device Manager to see what it shows as the model number of your Realtek PCIe GBE Family Controller.
    If you are not sure, then what is the brand and model number of your motherboard or computer? I'll see if I may be able to find the latest driver for it. :)
    Unfortunately, my Device Manager doesn't show the model number. I have attached a snapshot showing what Device Manager lists and showing details of the driver and its version.
    I have an Asus P7H55-M motherboard.
    Attached Thumbnails Attached Thumbnails SFC /SCANNOW Command - System File Checker-realtek-network-adapter-snapshot.jpg
  2. Posts : 71,977
       #651
    It's a Realtek RTL8168E network adapter. :)
    Latest driver from Realtek:
    Realtek
    Driver from Asus, but old:
    Motherboards - P7H55-M - ASUS
  3. Posts : 9
       #652
    Realtek
    1. If it's a RTL8168E, how do I uninstall the driver for RTL8187SE, which is the damaged file per the SFC CBS.log?
    2. For the RTL8168E driver, which version should I download - "Windows 7 and Server 2008 R2 Auto Installation Program (SID:1669850)" or "8111DP DASH All-In-One installation kit for WinXP/Vista/Windows 7"?
    3. Or should I install the older Asus drivers first? If so, should I install the oldest one first & then each newer one, and then the newest Realtek driver last?
    Thanks for the help!
  4. Posts : 71,977
       #653
    You should be able to just install the new driver, and be fine. :)
    Q2) Yes.
    Q3) If the one from Realtek has an issue, then you could use this one instead after uninstalling the one from Realtek.
  5. Posts : 9
       #654
    Q2) Yes.
    I downloaded & installed the latest Realtek RTL8168E driver successfully. However, I did not uninstall the previous driver beforehand. After the install, I ran SFC /VERIFYONLY, rebooted, & then ran SFC /SCANNOW. Unfortunately, I still get the same message regarding the RTL8187SE file not able to be repaired. Should I have uninstalled the driver first & then install the new driver afterward? Should I uninstall & reinstall the driver now?
    Also, I'm still getting the messages regarding the missing DLL file. Why doesn't it give me a DLL file name, so I know what to replace? Ugh, this is so frustrating! I tried uninstalling & reinstalling a few of the programs (four to be exact), but that didn't help. I have 12 programs (discovered so far) that I get this error message on, so uninstalling & reinstalling all of them will be a major pain. Any thoughts?
  6. Posts : 71,977
       #655
    If you're not having any issues with your network, then I wouldn't worry about the SFC issue.
    For the .dll issue, you'll need to most likely uninstall and reinstall the affected programs.
  7. Posts : 3
    Win 7 Pro x64
       #656
    I ran sfc /scannow and it says that "Windows Resource Protection didnot find any integrity violation". Yes, My Win 7 has a Win 95 like UI. What gives? Do I need to do something else?
  8. Posts : 71,977
       #657
    Hello yaip, and welcome to Seven Forums.
    That indicate that SFC didn't find any issues with your system files.
  9. Posts : 3
    Win 7 Pro x64
       #658
    So how do I get my Win 7 "skin" back?
  10. Posts : 71,977
       #659
    I assume that it restored a modified system file for the custom skin back to default for the default Windows 7 skin.
