Windows 7: SFC /SCANNOW Command - System File Checker
How to Repair Windows 7 System Files with System File Checker
Published by Brink
09 Jan 2009
information   Information
The sfc /scannow command (System File Checker) scans the integrity of all protected Windows 7 system files and replaces incorrect corrupted, changed/modified, or damaged versions with the correct versions if possible.
Tip   Tip
If you get the Windows Resource Protection Could Not Start the Repair Service error when trying to run SFC, then make sure that the Windows Modules Installer service is enabled, click on Start, and set to Manual.
Services - Start or Disable
OR
Copy and paste the command below in the elevated command prompt, and press Enter. After the Windows Modules Installer service has started, try running the SFC command again
net start trustedinstaller
Note   Note
The KB3022345, KB3035583, and KB3068708 updates will cause SFC to give you a false mismatch message in SFC for files related to these updates.
You can safely ignore these results in your SFC details since it will not affect SFC from being able to repair other system files.
warning   Warning
Be aware that if you have modified your system files as in theming explorer/system files, running sfc /scannow will revert the system files such as explorer.exe back to it's default state. Make the appropriate backups of your system files that you have modified for theming if you wish to save them before running sfc /scannow.
CONTENTS:
  • Option One: To Run the SFC /SCANNOW Command at Boot
  • Option Two: To Run the SFC /SCANNOW Command in Windows 7
  • Option Three: How to See and Read Only the "SFC" Scan Results from the CBS.LOG
SFC /SCANNOW Command - System File Checker OPTION ONE SFC /SCANNOW Command - System File Checker
1. For how, see METHOD TWO at this link: SFC /SCANNOW : Run in Command Prompt at Boot
Note   Note
Using OPTION TWO below is recommended if able.
If you would like to get help with your SFC issue, then be sure to upload and attach your sfcdetails.txt file from OPTION THREE below in your post.
SFC /SCANNOW Command - System File Checker OPTION TWO SFC /SCANNOW Command - System File Checker
1. Open an elevated command prompt or an elevated PowerShell, and do step 2 or 3 below for what type of scan you would like to run.
2. To Scan and Repair System Files
NOTE: Scans the integrity of all protected system files and repairs the system files if needed. Please see red WARNING box at the top of this tutorial.
A) In the elevated command prompt, type sfc /scannow, press Enter, and go to step 4 below. (see screenshot below)
NOTE: This may take a little bit to finish.
SFC /SCANNOW Command - System File Checker-command-1.jpg
3. To Only Verify if the System Files are Corrupted
NOTE: Scans and only verifies the integrity of all proteced system files only. This command will not change your system files as in the red WARNING box at the top of this tutorial.
A) In the elevated command prompt, type sfc /verifyonly, press Enter, and go to step 4 below.
4. When the scan is complete, hopefully you will see all is ok like the screenshot below.
Note   Note
  • If SFC could not fix something, then run the command again to see if it may be able to the next time. Sometimes it may take running the sfc /scannow command 3 or more times to completely fix everything that it's able to.
  • If not, then download and run the 32-bit (x86) or 64-bit (x64) System Update Readiness Tool for your same installed 32-bit or 64-bit Windows 7, restart the PC afterwards, and try the sfc /scannow command again.
  • If still not, then try using OPTION ONE above to run the sfc /scannow command at boot.
  • If still not, then you can attempt to run a System Restore using a restore point dated before the bad file occured to fix it. You may need to repeat doing a System Restore until you find a older restore point that may work.
  • If still not, then you can use the steps in the TIP box in the OPTION THREE section below to manually replace the files that SFC could not fix if there are not to many fix.
  • If there are to many files to manually fix, or you prefer not to use OPTION THREE below, then you could do a repair install without losing anything.
SFC /SCANNOW Command - System File Checker-finished.jpg
5. When done, close the elevated command prompt.
SFC /SCANNOW Command - System File Checker OPTION THREE SFC /SCANNOW Command - System File Checker
Note   Note
When SFC runs, it logs it's actions into the C:\Windows\Logs\CBS\CBS.log. The steps in this option will show you how to see only the specific SFC entries with the [SR] tags in this CBS.log. This can be helpful to show you what files SFC could not fix automatically if you wanted to try and manually replace them.
1. Open an "elevated command prompt" (right click -> Run as administrator).
2. In the elevated command prompt, copy and paste the command below, and press Enter. (See screenshot below)
NOTE: This will place a sfcdetails.txt file on your desktop with only the SFC scan result details from the CBS.LOG in it.
findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt"
SFC /SCANNOW Command - System File Checker-sfcdetails.jpg
3. Close the elevated command prompt.
4. Open the sfcdetails.txt file on your desktop to see the SFC scan details in the CBS.LOG.
5. You can safely delete the sfcdetails.txt file afterwards if you like.
Tip   Tip
If you need to replace a corrupted system file that SFC cannot fix, then this will show you how to by extracting a new copy directly from your Windows 7 installation DVD.
Extract Files from Windows 7 Installation DVD
18 Jan 2009   #1
shadowminx69
Windows 7 Build 7000
would it be a bad Idea to make a task to run this each night? not sure if it would be a good Idea or not. Hit me back
18 Jan 2009   #2
Romulinx2
Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
Thanks, I forgot about this. I used to use it in early editions of windows. Run it and sorted some errors.
18 Jan 2009   #3
darkassain
Quote   Quote: Originally Posted by shadowminx69 View Post
you shouldnt have any problem with it...
18 Jan 2009   #4
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by Romulinx2 View Post
You're welcome Romulinx2.
07 Feb 2009   #5
thunder2008
Windows 7 RC 7100
Very useful information running the sfc atm, thank you for this thread.
07 Feb 2009   #6
Brink
You're welcome Thunder2008.
01 Mar 2009   #7
anykey
Dual boot XP Pro and Seven/7127
Good to see this again.
Thanks for the reminder.
Didn't you used to put some letters/codes as a suffix, something such as /* or /?. This was to fix things.
01 Mar 2009   #8
Brink
Hello Anykey,
You could type sfc /? in the elevated command prompt for a complete list of sfc commands to use, but sfc /scannow is the best option to scan and repair all protected system files command. No other suffixes that I know of though.
SFC /SCANNOW Command - System File Checker-sfc_list.jpg
01 Mar 2009   #9
anykey
Thanks Brink, perhaps I am thinking of the old chkdsk.
I was always taught to do it something like this:
chkdsk /f /r /v /e
system file checker log does not show file not repaired
Ran system file checker and it said it found corrupted files but could not repair all of them. Looking at the log is not helping. I have posted the last several lines as they are representative of the entire log with the exception of the last few lines that mention an actual repair. Where is the...
Performance & Maintenance
System file checker
Does anyone have a link where I can find a list of all the commands ( and what they do) for System file checker in Windows 7 ? thank you Joe
SYstem File Checker Result - CBS.Log file says Access Denied
I have just completed a System File Check and some repairs were done I was told that the relevant report could be seen at C:\WINDOWS\LOGS\CBS\CBS.LOG. When I Clicked on that I got Access Denied How can I Open that log file? I am the Administrator
system file checker
long story short l have a external drive which keeps on telling me to scan it, l havent the space to backup the content on it and reformat etc and whenever l use the file system scanning tools it seems to stop at a specific record at which point l have to disconnect and reconnect the drive again to...
New System File Checker : sfc /scannow tutorial
I hope this will be a help to some and I would appreciate any feed-back. :) SFC /SCANNOW : Run in Command Prompt at Boot Edit: I've just added a Method Two to this. :)
Chillout Room
System File Checker
I am trying to use system file checker tool (sfc.exe) and I am running win7 ult 64bit. I am CERTAIN that I have corrupted files in windows. When I try to use any of the programs like Windows Experience, Generate a system health report, or look at files in Event Log(event log is unable to give me...
BSOD Help and Support
