Internet Explorer - JavaScript Timer Frequency Power Plan Settings
    How to Change "JavaScript Timer Frequency" Power Option Setting for Internet Explorer
    This tutorial will show you how to change the setting for the JavaScript Timer Frequency power option for IE9, IE10, and IE11 in Windows 7, Windows 8, and Windows 10.
    There have been a very few reports of some users having possible increased battery drain or sleep issues with the Maximum and Power Saving settings enabled, respectively. These may or may not be mis-identified issues, but you may want to test out the different settings from the default if they apply to you.
    IE9, IE10, and IE11 has a power setting in Windows 7 and Windows 8 Power Options, called JavaScript Timer Frequency. This is tied in with the IE9, IE10, and IE11 javaScript engine.
    The apparent reasoning behind the two available settings of this new Power Option are basically summed up by this line in the IEBlog below:
    An optimized experience on platforms from multi-core desktops to netbooks and mobile devices. User code in an HTML and JavaScript application is mostly single-threaded, but on today’s modern multi-core machines, browsers should find ways to use other cores intelligently to improve performance. At the same time, browsers must also run well on netbooks and low-power machines.
    While on the Power Saving option, this will slow down the execution of JavaScript in IE9, IE10, and IE11 which will also lower power consumption. This is the automatic setting on laptops, netbooks.
    The two settings are as follows:
    Maximum Performance: (default on desktops/plugged in devices) for optimal JavaScript performance in IE9 when power consumption or battery life is not critical or required.
    Maximum Power Savings: (default on laptops, etc) ideal when power consumption and battery life is important, such as a laptop, netbook, etc.
    Reducing JavaScript Timer Frequency can slow down the java script animations and execution in Internet Explorer which in turn can save battery life. If you want faster browsing in Internet Explorer, then you might want to change this setting to "maximum performance" in power settings. Slower performance is a compromise to save battery life. By default, when using a PC on battery, Internet Explorer will automatically switch to "maximum power savings" for JavaScript Timer Frequency.
    Here's How:
    1. Open the Control Panel (icons view), and click/tap on the Power Options icon.
    Internet Explorer - JavaScript Timer Frequency Power Plan Settings-capture5.jpg
    2. Click/tap on Change Plan Settings.
    Internet Explorer - JavaScript Timer Frequency Power Plan Settings-capture.jpg
    3. Click/tap on Change Advanced Power Settings, and scroll down where it says Internet Explorer.
    Internet Explorer - JavaScript Timer Frequency Power Plan Settings-capture2.jpg
    4. Pick either the Maximum Performance, or Maximum Power Savings setting that applies if you wish to change it from the default setting, and click/tap on OK.
    Internet Explorer - JavaScript Timer Frequency Power Plan Settings-capture3.jpgInternet Explorer - JavaScript Timer Frequency Power Plan Settings-capture4.jpg
    That's it.
  1. Posts : 115
    Windows 7 Home Premium 64 Bit
    May I ask what are the benefits & disadvantages are?
  2. Posts : 71,977
    Hello Harvey,
    It's basically just to either have maximum browser performance of any running java scripts in Internet Explorer, or to save battery life by reducing performance. :)
  3. Posts : 115
    Brink said:
    Hello Harvey,
    Ohh ok lol. Is it true Java has horrible security capabilities? I read somewhere that Java tremendously blows for lack of a better term.
  4. Posts : 71,977
    Yeah, I wouldn't recommend using anything with Java if you can help it.
  5. Posts : 115
    Haha. Thanks man I just had a gut feeling lol.
  6. Posts : 71,977
    Anytime mate. :)
  7. Posts : 115
    Brink said:
    Anytime mate. :)
    So it's safe to say the scripts that IE uses is just as horrible?
  8. Posts : 71,977
    No, it's just Java in general I wouldn't trust.
  9. Posts : 115
    Cool.
