Internet Explorer Add-ons - Enable or Disable Add-On Manager
    How to Enable or Disable Managing Internet Explorer Add-ons
    This will allow you to enable or disable all or specific users to have the ability to enable or disable Toolbars and Extensions add-ons through the Internet Explorer Add-On Manager in Windows.
    You must be logged in as an administrator to be able to do the steps in this tutorial.
    EXAMPLE: Internet Explorer Add-On Manager Enabled and Disable
    Internet Explorer Add-ons - Enable or Disable Add-On Manager-enabled.jpgInternet Explorer Add-ons - Enable or Disable Add-On Manager-disabled.jpg
    OPTION ONE
    Using a REG File Download
    NOTE: This option will affect all users.
    1. To Enable Users to Manage Internet Explorer Add-ons for Only Current User
    A) Click/tap on the Download button below to download the file below.
    Enable_Manage_Internet_Explorer_Add-ons.reg
    B) Go to step 3.
    2. To Disable Users from Managing Internet Explorer Add-ons for Only Current User
    Disable_Manage_Internet_Explorer_Add-ons.reg
    4. Double click/tap on the downloaded .reg file to merge it.
    5. Click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK when prompted.
    6. If open, close all instances Internet Explorer and reopen one to apply the change.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, Windows Components, and Internet Explorer. (see screenshot below)
    3. In the right pane of Internet Explorer, double click/tap on Do not allow users to enable or disable add-ons to edit it. (see screenshot above)
    4. To Enable Users to Manage Internet Explorer Add-ons
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    B) Go to step 6.
    5. To Disable Users from Managing Internet Explorer Add-ons
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click/tap on OK. (see screenshot below)
    8. If open, close all instances Internet Explorer and reopen one to apply the change.
  1. Posts : 1,747
    window's 7
    another useful knowledge for IE users BRINK. thumbs up
  2. Posts : 5
    windows7 homw premium 64bit
    Only one add-ons enable disable grey out
    I cannot enable one of the add-ons, both enable and disable are grey out. other add-ons are working fine.
    I reinstall it, disable anti-virus. Change file's security and other.. , not working.
    I created a new user account, this add-one works normal in new account.
    I could not figure out how to fix it in original account.
  3. Posts : 72,043
    Hello mxchen, and welcome to Seven Forums.
    What add-on is this for?
    Please go ahead and post a screenshot showing the full screen for this to see if it may help ID an issue. :)
  4. Posts : 5
    Thanks Brink.
    It is AxSubmitControl Class. I attached the screenshot here.
    Mxchen
    Attached Thumbnails Attached Thumbnails Internet Explorer Add-ons - Enable or Disable Add-On Manager-manageadd-ons.jpg
  5. Posts : 72,043
    It does seems like managing IE add-ons may have been disabled. See if using step 1 in OPTION ONE of this tutorial may be able to help afterwards if you have not already.
    You may need to log out and in or restart the PC if simply closing and reopening IE doesn't apply it.
    If that still doesn't help, then export the two keys below from your registry and upload them. I'll take a look to see if there may be some other policy set that may be affecting this.
    HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Restriction
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Restrictions
  6. Posts : 5
    The values both are 0.
    All other add-ons are normal, I can enable or disable them
  7. Posts : 72,043
    Did you have any other entries at those registry locations?
  8. Posts : 5
    Policy
    No other entry
    [HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Restrictions]
    "NoExtensionManagement"=dword:00000000
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Restrictions]
    Internet Explorer Add-ons - Enable or Disable Add-On Manager Attached Files
  9. Posts : 72,043
    Even though they are set to zero, just as a test, use step 1 in OPTION ONE to delete these DWORD values since they should not be there by default, and restart the PC.
    If that still doesn't help, then it may be easier to use the new account that it does work in instead.
