Windows 7: USB Driver - General Fix for Problems
17 Jun 2012   #20
0pTicaL
Quote   Quote: Originally Posted by nwnc14344 View Post
where do i find the INFCACHE.1,,,, what do you mean by uninstall? you mean that i will uninstall all the USB ports on my LAptop then the INFCACHE.1 will appear? sorry im just a newbie for this problem please help me
INFCACHE.1 is located in C:\Windows\System32\DriverStore
The rest of the instructions are clearly listed in the original post by pooch if you scroll back up.
27 Jun 2012   #21
rowed79
similar problem but pooch's solution won't hold
Hey all,
So I'm having a similar problem, I think, but the general solutions doesn't totally work.
I have at least 4 different USB controllers (one multi-card reader in front, another 2-port in front with the headphone/mic jacks, two in back, and a 3.0 in back)... but I'm not perfectly sure how to identify any of these in the Device Manager.
Nonetheless, Pooch's solution works for me, but only for the reboot immediately following the procedure. On the next reboot, all but one of my USB controllers won't start (I get the code 10 in the device manager). But, if I go into the Device manager, and 'disable' each controller, then 'enable' each controller, I can get all the ports to work. Until the next time I reboot the system. I tried the pooch-solution three different times, all with the same outcome, one good reboot, then back to 'code 10' on all but one bank of ports.
I'm doing my best to avoid reinstalling windows, and since eventually I can get all the ports to work, I feel like it's just a software problem. I'd prefer not to have to access the device manager every morning when I turn the machine on, so I'm hoping for some sort of solution.
This basically started happening without any major hardware changes. I did have a USB flash drive that was causing my problems, and I started troubleshooting that, and I'm guessing maybe some 1 got changed to a 0 in the process.
Any thoughts?
--Dave
20 Jul 2012   #22
ConnorP
Windows 7 Professional 64 bit
Just a quick question regarding the above tutorial:
I am having intermittent success in getting my system to recognise a Freecom external USB HDD.
Freecom themselves have directed me to the infcache.1 renaming process as described above, but their version said to delete only shaded entries in the USB controllers list. Also I could not rename infcache.1 even though I set full permissions, and ultimately changed ownership of it. I even tried to move it out of the DriverStore folder - which I could do, but Windows did not rebuild it and it would not let me put the old one back! I ended up using System Restore to revert to the setting from 24 hours previous. So I am back where I started.
If I delete ALL listing under Device Manager > USB controllers, as directed above, will that impact on the fact that both my keyboard and mouse are connected via USB? My mobo does not have PS2 connectivity.
07 Aug 2012   #23
x BlueRobot
Good tutorial (:
01 Sep 2012   #24
WallyxD
On the step where we have to open windows explorer, and i type in INFCACHE.1 nothing comes up.
01 Sep 2012   #25
Brink
64-bit Windows 10 Pro
Hello Wally, and welcome to Seven Forums.
Did you select Computer in the navigation pane first to search for INFCACHE.1 in Computer?
01 Sep 2012   #26
WallyxD
Yes I did. I figured it out though. I just did a system restore to two days ago and started the tutorial over. So far everything's fine. Just one question, when it says connect usb device, does that mean just insert the usb cord.? Or should I insert the cord and my phone.?
01 Sep 2012   #27
Brink
Good news. Yes, it means to connect both to connect the device completely.
01 Sep 2012   #28
WallyxD
I kept my phone plugged in while it was restarting. When the computer started back up, it charged, but that only lasted for a few seconds. Anyone know why.?
14 Oct 2012   #29
natural4862
Windows 7 Professional x32
For anyone who cannot delete the INFCACHE.1 file, there's a solution:
After creating "Administrators" in Step 5, please check all the box under "Allow" (such as totally control, edit, read&execute, etc -> I'm using a Chinese OS so the wordings may not be exactly the same
That should fix and can delete the file now
General Driver Question
Hello everyone, I am installing some software on a few Windows 7 - 32 bit PCs. I am watching the installation and there comes a point where the installation stops and tell me that my drivers are not signed and to select I want to install them or not. However if I do nothing the screen goes...
Drivers
General HomeGroup problems
I haven't been much into network file sharing, printer, etc, but I recently looked at my networking window and realized I can't create a HomeGroup or even view the network map (I believe the two problems are related). 1. A while ago, I removed the HomeGroup button from the navigation panel and...
Network & Sharing
Can't start up my computer. (Driver problems, BSOD, other problems)
Hi I hope I'm placing this in the right section, if not, then could someone tell me where to put it and I'll post it again. I've got a Samsung RV510 laptop with Windows 7 HP 64 bit. About 2 weeks ago, I was watching a Youtube video, had Spotify and Facebook open too, and my computer...
BSOD Help and Support
Anybody have problems dual booting or with partitions in general
i am dual booting 7 64 bit and ubuntu linux i was wondering if anyone has any issues with this type of setup or just with partitions in general
General Discussion
General Help with a few problems.
Hello guys, Im new here and have found your lovely community to be really helpfull but Im still stuck on a handfull of problems with My Windows 7 run PC. If anyone could try and help run me through the following Id be very greatfull. But please bare with me as Im not 100% literate with PC's...
General Discussion
Help - RAM Diagnostic Tool and General Win7 Problems
I wasn't sure whether to put this in the hardware forum so forgive me and please move if appropriate! I purchased 4GB of RAm a few mnths ago and also got a copy of Vista HP64. From the get go I had all sort of issues in Vista - games would not run, the OS seemed to crash a lot, would get...
General Discussion
