Windows 7: USB Driver - General Fix for Problems
15 Oct 2012   #30
Win 7 Ultimate 64
Pooch, this bsod was driving me CRAZY!!! The usb mouse would disconnect every once in a while and unplugging/plugging back in solved the issue.
Then all of a sudden, after about 3 s/w installs and MS Updates, the fe error.
Thought it was the mobo. Then h/w. Uninstalled the new s/w. Nope.
About to go out and buy new mobo, figuring it was the mouse/keyboard inputs.
Found this tutorial. Holy Mackerel!!! The number of greyed out usbs was over 30.
The issue of Admin addition not working is because you have to add Rights to that user; are not automatically granted.
Thank you pooch, very much.
05 Nov 2012   #31
win 7 ultimate
hi pooch,
Help please,
I have an Imation Usb Flash disk 4GB nano pro,
everytime I plug in to my Toshiba Laptop A300 using Windows 7
it says windows update cannot find the driver ,
so it say usb device not recognized and I cant see it in my Devices with removable storage.
When i go to device manager, i can see the unknown device as nano pro
but no driver installed, it has an yellow exclamation mark. tried update driver but failed because Windows 7 cannot find it online.
When i run Ubuntu OS on the same laptop,
usb imation is working so i guess theres a problem only with Windows 7 driver or Windows 7 OS .
I followed your instruction here but still it doesnt work because it doesnt have a driver,
Also, i tried a different brand usb flash disk and its working, only this Imation brand is not.
Thanks a lot
28 Nov 2012   #32
7 ultimate 32bit 4off
Mmmm none of this works for me i have 2 different systems same hardware different mother boards both asus
1 a p5VD1_X(X-XP3) and a P5bw-LA (x-VISTA) both newdrives to windows 7 ultimate everthing is ok with the P5VD but none of the usb ports internal and external work on the P5BW if i put the vista drive back in all works well so problem is not hardware but is windows seven dose not like my board althoug seven adviser said all was ok.
All usb ports are live but do not read or write they show in device manager
I have done all as above but does not work so no need to go back over that!
ran driver wizard and all drivers are upto date.
When i compare device manager USB's they are titled different?
Anyone anyfurther Ideas
16 Dec 2012   #33
Window 7 Pro 64 bit
For those asking about how to delete the infcache.1 file, I deduced after adding administrators it would be necessary to check the boxes regarding permissions.
29 Dec 2012   #34
Windows 7 home premium 32bit
My system has been freezing a lot so this looked like a good option. I do not have a wired mouse so had to use a USB version. Have restarted the computer but none of the USB ports seem to be active; that is to say, none of the devices respond, including the mouse and keyboard! Is there a way that I can activate the USB ports?
CANCEL - sorry, after rebooting (a couple of times) the usbs became active!
13 Jan 2013   #35
Windows 7 Ulimate x32
USB Driver Problems
I am having trouble with my laptop (HP Compaq 6715b) USB ports as I have followed each step by pooch about three to four times. I have searched Google and Youtube but no luck except this thread.
Before having this problem, my USB ports were working fine about five (5) to eight (8) days ago. These ports cannot be dead as I have tested an old USB stick (to create the new INFCACHE.1 file when following pooch's steps) and my USB mouse and keyboard. Both work in all four (4) USB ports and no errors.
Once I put in the devices that I need for data and transferring data to is - Seagate External HDD which is brand new bought just before Christmas 2012, Samsung smartphone and USB stick. All these devices give me the balloon error "USB Device Not Regonized". Strangely enough the USB stick that I inserted to refresh the INFCACHE.1 file by following all steps given by pooch works.
Also, these devices that I am trying to get to work, all of these devices work on my PS3 but not on my HP Compaq 6715b laptop.
If anyone can please help me that would be much appreciated as I need to get data from these devices and also copy data onto other devices for back up.
Thank you!
28 Mar 2013   #36
Windows 7 x64
I have solved my USB copy problems on my Asus P8P67 Pro motherboard by updating the BIOS to the latest version.
04 Apr 2013   #37
Windows 7 Home Permium, Service Pack 1, 64bit
I get stuck at following poing:
5. Type Administrators in the window with the blinking cursor, Click OK.
After clicking on OK as you mentioned in point 5 following widows appears.
it says:
Can not find an object named "Administrators". Check the accuracy of the selected object types and location, and make sure you typed the object name correctly, or remove this object from the selection.
( ) Correct information object and search again
( ) Remove "Administrators" selection
What do I have to do in this window?
Thank you for your help!
29 May 2013   #38
Windows 7 Home Premium
Thank you SOOO MUCH!
I've been trying to get my wireless mouse to work for almost a week now. This tutorial finally fixed it along with a few other devices that were giving me issues on the USB front. I can't say enough how much this helps me out, I hate using a touch pad and it's been driving me crazy!
30 May 2013   #39
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
Quote   Quote: Originally Posted by Xaelra View Post
I Googled for days attempting to fix my wireless mouse stuttering. This fix made a 99% improvement.
Tutorial Tools Search this Tutorial
Search this Tutorial:
Advanced Search
Windows 7 Tutorial Category
General Driver Question
Hello everyone, I am installing some software on a few Windows 7 - 32 bit PCs. I am watching the installation and there comes a point where the installation stops and tell me that my drivers are not signed and to select I want to install them or not. However if I do nothing the screen goes...
General HomeGroup problems
I haven't been much into network file sharing, printer, etc, but I recently looked at my networking window and realized I can't create a HomeGroup or even view the network map (I believe the two problems are related). 1. A while ago, I removed the HomeGroup button from the navigation panel and...
Network & Sharing
Can't start up my computer. (Driver problems, BSOD, other problems)
Hi I hope I'm placing this in the right section, if not, then could someone tell me where to put it and I'll post it again. I've got a Samsung RV510 laptop with Windows 7 HP 64 bit. About 2 weeks ago, I was watching a Youtube video, had Spotify and Facebook open too, and my computer...
BSOD Help and Support
Anybody have problems dual booting or with partitions in general
i am dual booting 7 64 bit and ubuntu linux i was wondering if anyone has any issues with this type of setup or just with partitions in general
General Discussion
General Help with a few problems.
Hello guys, Im new here and have found your lovely community to be really helpfull but Im still stuck on a handfull of problems with My Windows 7 run PC. If anyone could try and help run me through the following Id be very greatfull. But please bare with me as Im not 100% literate with PC's...
General Discussion
Help - RAM Diagnostic Tool and General Win7 Problems
I wasn't sure whether to put this in the hardware forum so forgive me and please move if appropriate! I purchased 4GB of RAm a few mnths ago and also got a copy of Vista HP64. From the get go I had all sort of issues in Vista - games would not run, the OS seemed to crash a lot, would get...
General Discussion
