Windows 7: USB Driver - General Fix for Problems
08 May 2014   #50
Windows 7 Ultimate 64bit
Hi everyone
I cant succeed to delete the faded USB driers. They remain in the same place. help on what can I do please.
19 Jun 2014   #51
Windows 7 Familial 64-bit
useless this whole forum! No one explains the easy way for a common man, No way except to repair the problem with IT technician!
19 Jun 2014   #52
windows 7 home 64bit
Hi Welcome to Seven Forums .. Perhaps if you start a new Thread and explain the problems you have some one just might offer to help you ...
30 Jun 2014   #53
I've followed the steps in pooch's tutorial to no avail. There's still something wrong in my USB drivers.
- I cannot install a new mouse (works fine in another computer) due to driver error.
- When I plug a Bluetooth dongle, it works fine but there are 3 "Bluetooth Peripheral Device" warnings in "Other Devices" and many entries in Human Interface Devices. Without the dongle, there are only 2 entries.
- If I uninstall the 3 warnings above, when I unplug the Bluetooth dongle, there's a message "Installing Device Driver Software"
- INFCACHE.1 has always the same size - in my case 1769KB.
ACER laptop, Win 7 home Premium,
05 Jul 2014   #54
windows 7
Hi guys,
I was having problem with my logitech keyboard. My wireless mouse was working fine, but was not able to connect to keyboard receiver.
i did exact same way your instructions above. My problem has been solved. TVM.
29 Aug 2014   #55
W7 Ult x64
Followed your instructions to the "t" and it FINALLY cleared up my USB problem! Thanks!
03 Sep 2014   #56
Fixed some devices but not all
Hi there,
Thanks for this tutorial it was very clear and easy to follow. I had an interesting variation though:
After I had deleted the INFCACHE file it did not return when I plugged in a previously functioning USB device. In fact none of my devices worked. So what I had to do was shutdown, plug in the devices that I wanted to use and then restart the computer. Upon restart the INFCACHE file was there and my previous devices were working. Not bad. But unfortunately, while this fixed a portable hard drive that was not working, it didn't fix the external sound card that I REALLY need to have working.
Should I just keep repeating the process?
Many thanks in advance
18 Sep 2014   #57
I'm a bit confused as to exactly which USB devices need to be deleted. The original post said just the faded ones, while Pooch's reply to CAGW, all the drivers are highlighted in yellow, and Pooch says to get rid of all of them. I'm a bit reluctant to do this as my mouse is wireless and so relies on USB drivers. Can someone please explain exactly what to do?
07 Nov 2014   #58
Windows 7 Ultimate x64, Windows 7 Home Premium 32bit
Procure a wired mouse, as was strongly recommended in the beginning of the article. It will load automatically after you reboot or you can plug it in after you have deleted the potentially offending input devices.
13 Nov 2014   #59
Windows 7 32 Bit Professional
My PC not recognising any Android phones
Dear Pooh, I read your article many times. I have a problem. My PC just does not recognise any Android phones. Tried step by step what you have written in your article and was successful in carrying out all the tasks suggested by you. In the end, my PC recognised all USB gadgets except my HTC Android phone which was my main problem as all other gadgets were earlier also being recognised. There is nothing wrong with my phone as I tried 3 other Android phones but they are just not recognised by the PC. Had lots of hope from your very informative article but got disappointed in the end. Whenever the Android is connected, it shows HTC MTP Device Failed. Attaching the message file for your viewing. Kindly help me. I have been trying to sort out this problem for the last 4 days but in vain. If Mr. Pooh is not there on the scene, can anyone help me?
Thanks & Regards.
Colonel Narender Singh (Retd)
Tutorial Tools Search this Tutorial
Search this Tutorial:
Advanced Search
Windows 7 Tutorial Category
General Driver Question
Hello everyone, I am installing some software on a few Windows 7 - 32 bit PCs. I am watching the installation and there comes a point where the installation stops and tell me that my drivers are not signed and to select I want to install them or not. However if I do nothing the screen goes...
General HomeGroup problems
I haven't been much into network file sharing, printer, etc, but I recently looked at my networking window and realized I can't create a HomeGroup or even view the network map (I believe the two problems are related). 1. A while ago, I removed the HomeGroup button from the navigation panel and...
Network & Sharing
Can't start up my computer. (Driver problems, BSOD, other problems)
Hi I hope I'm placing this in the right section, if not, then could someone tell me where to put it and I'll post it again. I've got a Samsung RV510 laptop with Windows 7 HP 64 bit. About 2 weeks ago, I was watching a Youtube video, had Spotify and Facebook open too, and my computer...
BSOD Help and Support
Anybody have problems dual booting or with partitions in general
i am dual booting 7 64 bit and ubuntu linux i was wondering if anyone has any issues with this type of setup or just with partitions in general
General Discussion
General Help with a few problems.
Hello guys, Im new here and have found your lovely community to be really helpfull but Im still stuck on a handfull of problems with My Windows 7 run PC. If anyone could try and help run me through the following Id be very greatfull. But please bare with me as Im not 100% literate with PC's...
General Discussion
Help - RAM Diagnostic Tool and General Win7 Problems
I wasn't sure whether to put this in the hardware forum so forgive me and please move if appropriate! I purchased 4GB of RAm a few mnths ago and also got a copy of Vista HP64. From the get go I had all sort of issues in Vista - games would not run, the OS seemed to crash a lot, would get...
General Discussion
