Windows 7: USB Driver - General Fix for Problems
16 Nov 2014   #60
Windows 7 Ultimate x64, Windows 7 Home Premium 32bit
disable USB debugging
Go here. "". Follow the instructions to access developer options. DISABLE Usb debugging. If that doesn't work right off the bat, try rolling back the driver for the phone.
20 Nov 2014   #61
Windows 7 32 Bit Professional
I tried as suggested in the reply but still no luck. Spoke to Microsoft people. They say the problem may be due to some changes done by some Windows update. Unfortunately, I removed all old restore points one day before this problem started. Some say, re-formatting Windows is the only answer. I can get it done but what is the guarantee the problem will not crop up again after sometime. I have tried a number of Android phones and problems continue with all of them. But they are all recognized on my Laptop. One thing is clear, there is no driver issue with any cell. It is some Windows file which is corrupted. Can some one help me in finding some solution other than re-formatting as it will create lot of problem in bringing my PC to shape one again after re-formatting.
20 Nov 2014   #62
If in fact Microsoft suggests that the conflict may be caused by one of their sometimes flaky updates AND if the phone is recognized by the other comp AND if both comps have the same operating system, see if you can compare the update history of both comps to see if the problem comp has an update that the good one doesn't. I know that might seem problematic but remember that both probably won't have the same hardware and while it could be time consuming at least you may be able to isolate a conflict with otherwise congruous hardware.
While you haven't indicated how old your comps are, there is another tack to take with USB issues and that is if the problematic comp is a desktop there is a possibility that the power supply or the board is no longer delivering the appropriate levels of power to the physical ports, particularly if they are all plugged in and/or all the devices are trying to draw the maximum amount of power according to their individual specifications beyond what is available. As odd as that might sound, I have discovered over the years that if you aren't willing to try another power supply, sometimes switching to an external powered hub or turning off, say, the front USB ports in the bios and moving everything to the back or to a powered hub may allow a tired P.S. to deliver the necessary power to the remaining ports. Remember that if a controller decides it can't supply the appropriate power to any particular port in an internal hub it will shift the device to a root hub that requires less power which may actually inhibit the device. This is very common with security cameras and capture devices for instance. Could this condition be caused by an incompatible update or drivers too advanced for the ancient 8 year old basic Microsoft controller and root hub drivers? Why not? That is, whether they know it or not, why so many people have suggested that you try the anecdotal solution of switching physical ports.
15 Dec 2014   #63
Hey Pooch, I followed the tut exactly except for step 6 because it said "You need permission to perform this action" "You need permission from Administrators to make changes to this file" but i am an administrator on this laptop and the problem still occurs. and I looked at Take Ownership Shortcut but nothing happened.
04 Mar 2015   #64
windows7 32 bit
thanks its working
20 Mar 2015   #65
Windows 7 64
Bless You
Thank you Thank you Thank you Thank you
For solving my problem!!!
25 Apr 2015   #66
Windows 7 Ultimate x86
can not install
I don't know what is happening to my Intel USB driver controller, I can not able to install in anyway...
I delete and install them again but nothing installed and unsuccessful warning pups up everytime
08 Oct 2015   #67
Windows 7 home premium 64 bit
Came to this topic after a BSOD problem 'fix' (updating graphics driver) corrupted my USB drivers
2 separate atikm?ag BSOD errors
and more specific to the USB problem
USB Ports Corrupted After Graphics Driver Update
I followed all the steps, and now, not only do I still not have working USB ports, but now I've lost my network printer.
It was only 2 Blue Screens - Why couldn't I have just left well enough alone?
07 Dec 2015   #68
Safe mode
Manifa, I had to do all the deletions mentioned (ALL, not just the greyed/faded out ones) but in Safe Mode, otherwise it didn't work. Yes, it was straight after a Windows Update, something got tweaked wrongly.
14 Jun 2016   #69
windows 10
INFCACHE.1 doesnt show up for me..
does that mean i dont have one?
or i cant find it?
plz help.
i needto fix this quick!
best regards
Tutorial Tools Search this Tutorial
Search this Tutorial:
Advanced Search
Windows 7 Tutorial Category
General Driver Question
Hello everyone, I am installing some software on a few Windows 7 - 32 bit PCs. I am watching the installation and there comes a point where the installation stops and tell me that my drivers are not signed and to select I want to install them or not. However if I do nothing the screen goes...
General HomeGroup problems
I haven't been much into network file sharing, printer, etc, but I recently looked at my networking window and realized I can't create a HomeGroup or even view the network map (I believe the two problems are related). 1. A while ago, I removed the HomeGroup button from the navigation panel and...
Network & Sharing
Can't start up my computer. (Driver problems, BSOD, other problems)
Hi I hope I'm placing this in the right section, if not, then could someone tell me where to put it and I'll post it again. I've got a Samsung RV510 laptop with Windows 7 HP 64 bit. About 2 weeks ago, I was watching a Youtube video, had Spotify and Facebook open too, and my computer...
BSOD Help and Support
Anybody have problems dual booting or with partitions in general
i am dual booting 7 64 bit and ubuntu linux i was wondering if anyone has any issues with this type of setup or just with partitions in general
General Discussion
General Help with a few problems.
Hello guys, Im new here and have found your lovely community to be really helpfull but Im still stuck on a handfull of problems with My Windows 7 run PC. If anyone could try and help run me through the following Id be very greatfull. But please bare with me as Im not 100% literate with PC's...
General Discussion
Help - RAM Diagnostic Tool and General Win7 Problems
I wasn't sure whether to put this in the hardware forum so forgive me and please move if appropriate! I purchased 4GB of RAm a few mnths ago and also got a copy of Vista HP64. From the get go I had all sort of issues in Vista - games would not run, the OS seemed to crash a lot, would get...
General Discussion
