Windows 7: Shadow Copies - Delete
20 Oct 2012   #20
mjf
Windows 7x64 Home Premium SP1
Very good tutorial as usual!
I had cause to check it out recently for an error I was getting on a PC I built (not for profit) for someone. I was getting Event ID: 55 source :NTFS with a reference to VSS and drive errors, run chkdsk. Doing HDD checks inc manufacturers plus others, the HDD appeared fine. I came across people suggesting - Clear VSS; Disable: Enable to overcome the problem. It seemed to work. Clearing the VSS is critical and this tute helps. I recommend the vssadmin command line method you describe.
Thanks.
20 Oct 2012   #21
Brink
64-bit Windows 10 Pro
Thank you Michael. Image updated.
28 Oct 2015   #22
musicollector
Windows 7 Enterprise 32-bit
Thanks for Option 2. I had been trying for a week to delete some shadow copy files to free up space on my drive, to no avail. I tried every trick in the book - until this. I am glad I came here.
28 Oct 2015   #23
Brink
I'm glad it could help.
How to delete system copies from partition?
Hi. I got a Fujitsu Amilo Xi 3670 laptop and i'm having some problems with it. There are 2 partitions each worth little under 300 GB of space: 1 for normal use of the laptop (C:) and 1 to store back ups and system copies (D:). The (D:) partition has a back up of 76,35 GB, so you'd think...
Backup and Restore
Two Copies of Win 7 in Separate Partitions - is it OK to Delete One ?
When I decided to move from XP to WIN 7 some time ago I initially ran a Dual Boot with both of these systems . I intended to run the XP OS until I became familiar with WIN 7 . Eventually I removed this Dual Boot and now run WIN 7 only. I forget the details now but I must have forgotten the...
Installation & Setup
What causes Event 36, volsnap - Shadow copies failed....
Hi, I keep noticing event viewer produces an Event 36, volsnap - The shadow copies of volume C: were aborted because the shadow copy storage could not grow due to a user imposed limit. I am really really curious as to what causes this error. There appears to be little knowledge on this...
Backup and Restore
Two different copies of same .dll
Hello, Apparently a problem I had thought fixed had resurfaced. Upon investigation I find that 2 programs use the same "delzip179.dll". I have had failures to load errors in Administrative Events. I've found that there are two different copies of the same named (above) .dll. Could this be the...
General Discussion
Why so many "created shadow copies at a time"
I usually delete all but the most recent shadow/previous versions when I tighten up my drives usually daily or every few days. Today when I looked at the previous versions screen both with 7 and vista there are multiple versions sometimes 6 or more within a few minutes.. See pic... I didn't install...
Performance & Maintenance
Shadow Copies
I apologize in advance for the length of the quote below, but it seemed necessary to put a proper focus on my question: If I comprehend what was said, the shadow copies are necessary for the proper functioning of the backup system and System Restore points, but while I do care about the...
