Windows 7: Shadow Copies - Delete
How to Delete Shadow Copies in Vista and Windows 7
Published by Brink
29 May 2011
information   Information
Shadow Copies (Previous versions) are copies of files and folders created by Windows Backup when you back up your files, and copies of files and folders that Windows automatically saves as part of a restore point. When system protection is turned on, Windows will only automatically create previous versions of files and folders that have been modified since the last restore point was made.
This will show you how to delete shadow copies in Vista Ultimate, Business, and Enterprise editions, and all editions of Windows 7.
warning   Warning
Deleting a shadow copy will also delete the restore point it was part of.
Shadow Copies - Delete BEFORE YOU START Shadow Copies - Delete
To View Volume Shadow Copies Details
NOTE: You will need to do this first to know what drives/volumes letters you have shadow copies on, and for how much disk space the shadow copies use before conitnuing on to the options below. The example shadow copies below contain two restore points on drive C: , and two backups on drive F: .
1. vssadmin list shadows
NOTE: This command lists existing volume shadow copies, the time the shadow copy was created and its location. You need this to see and know the Shadow Copy ID needed in OPTION TWO and OPTION THREE below, and to see how many shadow copies are on each hard drive letter.
A) Open a elevated command prompt.
B) In the elevated command prompt, type the command below and press enter.
2. vssadmin list shadowstorage
NOTE: This command lists the volume shadow storage space usage, the allocated space while a shadow copy is active and the maximum space that can be used. This is useful to see how much total space is being used on each hard drive letter by the shadow copies on it.
A) Open another elevated command prompt.
3. Set these command windows aside for easy reference when you do either OPTION ONE, OPTION TWO, or OPTION THREE below for what you would like to do to delete the shadow copies.
Shadow Copies - Delete OPTION ONE Shadow Copies - Delete
Delete Shadow Copies Using "Disk Cleanup"
NOTE: Disk Cleanup will delete all shadow copies and restore points saved to the selected hard drive letter except the most recent copy.
1. Open the Start Menu, type cleanmgr into the search box, and press Enter.
2. Select the drive/volume letter that you want to delete shadow copies on, and click on OK. (see screenshot below)
NOTE: You will not see this window unless you have more than one drive or partition on your computer.
3. You will now see this screenshot below for a moment. (see screenshot below)
4. Click on the Clean up system files button. (see screenshot below)
5. If prompted by UAC, then click on Yes (Windows 7) or Continue (Vista)
6. Repeat steps 2 and 3.
7. Click on the More Options tab, and click on the Clean up button in the bottom System Restore and Shadow Copies section. (see screenshot below)
8. Click on the Delete button. (see screenshot below)
9. Click on OK. (see screenshot below step 7)
10. Click on the Delete Files button for the final confirmation. (see screenshot below)
11. When the shadow copies and restore points are finished being deleted, Disk Cleanup will close.
Shadow Copies - Delete OPTION TWO Shadow Copies - Delete
Delete Shadow Copies Using "wmic shadowcopy delete" Command
WARNING: This option is for advanced users, and should not be tried by beginners.
1. Be sure you do the "BEFORE YOU START" section at the top first.
2. Open a elevated command prompt.
3. In the elevated command prompt, type wmic and press Enter. After a few seconds wmic:root\cli> will appear.
4. Copy and paste the command below and press enter.
shadowcopy delete
5. You will now be asked Y/N for if you wanted to delete the available shadow copies one by one. Type your answer and press Enter after each one. (see screenshot below)
Note   Note
The listed shadow copies that you answer Y/N to delete or not are referenced by their Shadow Copy ID number. You can compare this Shadow Copy ID number with the ones listed from step 1 in the "BEFORE YOU START" section to know for sure which one you are deleting or not.
For example, the Shadow Copy ID below for the one I deleted in step 5 above is the bottom shadow copy listed in my examples in step 1 of the "BEFORE YOU START" section for the C: drive. You can also compare the Shadow Copy Volume number between step 1 and step 2 in the "BEFORE YOU START" section for additional information about the shadow copy.
Shadow Copy ID
{1FAE1C7E-729C-4BE5-92D9-1FD643336AE1}
Shadow Copy Volume
{62027452-787d-11e0-8219-806e6f6e6963}
6. When finished, close all command prompts.
Shadow Copies - Delete OPTION THREE Shadow Copies - Delete
Delete Shadow Copies with "vssadmin delete shadows" Command
Note   Note
Only shadow copies that have the ClientAccessible type can be deleted using this command.
For example, if you look at my examples in step 1 in the "BEFORE YOU START" section, you will notice that only the C: drive/volume shadow copies have Client-accessible listed in their Attributes, and not the F: drive/volume shadow copies. This means that I can only delete the C: drive/volume shadow copies using this command. I would have to use OPTION TWO to be able to delete the F: drive/volume shadow copies instead.
3. Do step 4, 5, or 6 below for how you would like to delete the shadow copies.
4. To Delete the Oldest Shadow Copy on a Specific Volume
NOTE: This can be handy if you have more than one shadow copy on a drive/volume letter, and wanted to only delete the oldest one.
A) Type the command below and press Enter.
NOTE: Substitute C: in the command below for the drive letter that you want to delete the oldest shadow copy in instead.
vssadmin Delete Shadows /For=C: /Oldest
B) Type Y or N to delete the shadow copy or not. (see screenshot below)
C) Go to step 7.
5. To Delete All Shadow Copies on a Specific Volume
vssadmin Delete Shadows /For=C: /All
B) Type Y or N to delete the shadow copies or not. (see screenshot below)
C) Go to step 7.
6. To Delete a Specific Shadow Copy from Any Volume
NOTE: Substitute {Shadow Copy ID} in the command below with the actual Shadow Copy ID number of the shadow copy that you want to delete from step 1 of the "BEFORE YOU START" section.
vssadmin Delete Shadows /shadow={Shadow Copy ID}
For example, if I wanted to delete the 3rd shadow copy with the Shadow Copy ID of {ef4d4bbc-b569-4c1c-b8d3-a46af09e0ddf} in my example in step 1 of the "BEFORE YOU START" section, I would type this below.
vssadmin Delete Shadows /shadow={ef4d4bbc-b569-4c1c-b8d3-a46af09e0ddf}
C) Continue on to step 7.
7. When finished, close all command prompts.
19 Aug 2011   #1
whatttupG
windows 7 64 bit pro
wow... awesome post, I had no idea that stuff existed
however, this doesn't seem to be my problem, i have two physical HDD... a drive C and a drive P, using the above vssadmin list shadows.. i find there are 8 shadow copies, all on drive C, nothing on drive P
using the vssadmin list shadowstorage, i find drive C has 9.72 Gb of 10 Gb used, 1%, and again nothing for P
any other ideas? thank you for posting
19 Aug 2011   #2
JaidynM
Another great tutorial. Well done, Shawn.
19 Aug 2011   #3
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by whatttupG View Post
Hello WhatttupG, and welcome to Seven Forums.
You will not have one for the P: drive unless you have turned on system protection for the P: drive, then created a restore point.
19 Aug 2011   #4
Brink
Quote   Quote: Originally Posted by JaidynM View Post
Thank you Jaidyn.
19 Aug 2011   #5
kado897
As always a great tutorial Shawn. Did you know that CCleaner has a function to delete individual RPs except the most recent. It is in the Tools section. CCleaner - Optimization and Cleaning - Free Download
19 Aug 2011   #6
Brink
Hello Keith,
Thank you. Yep, it's a nice feature that was added to CCleaner.
System Protection Restore Points - Delete
19 Aug 2011   #7
kado897
Ah. I missed that one Shawn.
19 Aug 2011   #8
Brink
No problem mate. Thank you for mentioning it though.
19 Aug 2011   #9
xxxdannyxxx
Hello Shawn
Will this delete those annoying "system image restore points" under show more restore points. The only way Ive found to delete these is to redirect my windows backup to my image drive and then delete the images from there, but that forces windows backup to perform a full back up next time its scheduled.
Danny
How to delete system copies from partition?
Hi. I got a Fujitsu Amilo Xi 3670 laptop and i'm having some problems with it. There are 2 partitions each worth little under 300 GB of space: 1 for normal use of the laptop (C:) and 1 to store back ups and system copies (D:). The (D:) partition has a back up of 76,35 GB, so you'd think...
Backup and Restore
Two Copies of Win 7 in Separate Partitions - is it OK to Delete One ?
When I decided to move from XP to WIN 7 some time ago I initially ran a Dual Boot with both of these systems . I intended to run the XP OS until I became familiar with WIN 7 . Eventually I removed this Dual Boot and now run WIN 7 only. I forget the details now but I must have forgotten the...
Installation & Setup
What causes Event 36, volsnap - Shadow copies failed....
Hi, I keep noticing event viewer produces an Event 36, volsnap - The shadow copies of volume C: were aborted because the shadow copy storage could not grow due to a user imposed limit. I am really really curious as to what causes this error. There appears to be little knowledge on this...
Backup and Restore
Two different copies of same .dll
Hello, Apparently a problem I had thought fixed had resurfaced. Upon investigation I find that 2 programs use the same "delzip179.dll". I have had failures to load errors in Administrative Events. I've found that there are two different copies of the same named (above) .dll. Could this be the...
General Discussion
Why so many "created shadow copies at a time"
I usually delete all but the most recent shadow/previous versions when I tighten up my drives usually daily or every few days. Today when I looked at the previous versions screen both with 7 and vista there are multiple versions sometimes 6 or more within a few minutes.. See pic... I didn't install...
Performance & Maintenance
Shadow Copies
I apologize in advance for the length of the quote below, but it seemed necessary to put a proper focus on my question: If I comprehend what was said, the shadow copies are necessary for the proper functioning of the backup system and System Restore points, but while I do care about the...
