Bootable ISO - Create from an Older ISO
    How to Create a Bootable ISO from an Older ISO
    This small how-to covers just the fundamentals....
    • Extract a Boot Sector file
    • Create a new ISO with the extracted Boot Sector file
    Here's how:
    I use UltraISO for this method, but the basics should be the same for most ISO editing software
    Firstly, open/run UltraISO (or similar)
    1. Insert a Bootable DVD (e.g. Windows 7) Click Bootable then Extract Boot File from CD/DVD...
    2. Select the drive and destination for the BIF file then click Make
    3. You will be presented with the following message. Click Ok then 'Close'.
    4. Browse for the files you wish to have created into a Bootable ISO.
    5. Click Bootable and Load Boot File..., and browse for the file you just created.
    You can type *.* into the filename bar to view the new file
    6. Click the Burn Icon to burn the new Image to disk, or Save As to save the newly Bootable ISO.
    Hope this answers a lot of people's questions
  1. Posts : 803
    Windows 7 Professional x64
    very good post Shark!
    people asking a lot about this
  2. Posts : 63
    First really thanks :)
    Second i dont have DVD-RW so i will do bootable usb do yu know how ?
    These steps ok for usb ?
  3. Posts : 851
    win 7 build 7600.16385 x64
    should be moved to tutorial!!!
  4. Posts : 139
    Windows 7 x64 RTM
    use that for USB install
    auto method didnt work for me, but manual method worked perfect.
  5. Posts : 133
    Windows 7 x64 RTM
    Thanks for this Orbital Shark!
  6. Posts : 268
    Windows® 7 Ultimate x64 SP1
    Thanks a bunch Shark, just the info I needed!
    Not just that, but the pictures simplified it even further...good job!
    Simple & easy to follow instructions!
    Btw, this makes it even more simple for me as I already have & use UltraISO!
  7. Posts : 6,305
    Thanks for moving this Shawn. I wasn't too sure if I should post it as a tutorial based on what people can use the content for
  8. Posts : 16,161
    7 X64
    Nice tutorial Shark.
    I assume that is for when you have the windows files and you want to make a bootable .iso.
    Ultraiso is saving the bootimage file etfsboot.com , with a .bif extension.
    If you don't have a paid version of PowerIso, Ultraiso, etc - pretty much any burning suite you have will make a bootable iso for you.
    It will ask for the windows files - you know where they are - so browse to those, and it will also ask for the bootimage file .
    It is called etfsboot.com and is inside the windows files in the boot folder here :
    Very few app. can utilise etfsboot.com - so extract the boot image as per the tutorial, using the free versions of PowerIso, UltraIso, or MagicIso - and use that .bif or .img you extracted when asked.
    Just browse to it when asked by your burning app.
      My Computers
  9. Posts : 6,305
    Attachment 18700
    Ah, cool, nice addition
