Permanently Delete - Add to Context Menu
Page 3 of 10 FirstFirst 12345 ... LastLast
  1. Posts : 968
    Very nice Brink and very handy. :)
  2. Posts : 23
    Windows 7 Home Premium
       #21
    As per usual, I am much obliged.
    Well done, Shawn.
  3. Posts : 72,058
       #22
    Hello Hogtowner,
    Good to hear from you. Thank you. :)
  4. Posts : 209
    98SE/XP/windows7 ultimate 32bit
       #23
    Cool one , i like it
    thanks shawn
  5. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #24
    Hmm on any file if I choose Permanently Delete a window opens asking what program I want to use to open the file.
  6. Posts : 17,322
    Win 10 Pro x64
       #25
    Did you put this SDelete in your system32 folder?
    A) Download SDelete, save it to your Desktop, open the downloaded SDelete.zip file, extract (drag and drop) the sdelete.exe to your desktop.
    B) Right click on the extracted sdelete.exe file, click on Properties, General tab, and on the Unblock button.
    NOTE: If you do not have a Unblock button under the General tab, then the shortcut is already unblocked and you can continue on to step 1C.
    C) Copy and paste the unblocked sdelete.exe file into the C:\Windows\System32 folder, then click on Continue and Yes to approve copying it there.
  7. Posts : 24,479
       #26
    Well....nope. I just skipped to the reg downloads without reading. <whistles innocently>
    Thanks Derek!
  8. Posts : 17,322
    Win 10 Pro x64
       #27
    Thanks Derek!
    No Prob, Shawn usually makes them so easy I thought that might be it. :)
  9. Posts : 72,058
       #28
    LOL, I'm happy to hear that you guys got it sorted. :)
  10. Posts : 12
    is there anyway to have it remove the folder as well.
    i click delete perm on a folder and it just deletes everything in the folder but leaves directory there.
