"Notification Area Icons" Settings - Enable or Disable
    How to Enable or Disable Changing "Notification Area Icons" Settings in Windows 7 and Windows 8
    The notification area is a part of the taskbar that provides a temporary source for notifications and status. It can also be used to display icons for system and program features that are not on the desktop.
    This will show you how to enable or disable the ability of users to be able to change the taskbar Notification Area Icons settings in Windows 7 and Windows 8.
    You must be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: "Notification Area Icons" Disabled
    OPTION ONE
    Enable or Disable "Notification Area Icons" Settings using REG File
    1. To Enable the Ability to Change "Notification Area Icons" for All Users
    A) Click/tap on the Download button below to download the file below, and go to step 3 below.
    Enable_Notification_Area_Icons_Settings.reg
    2. To Disable the Ability to Change "Notification Area Icons" for All Users
    Disable_Notification_Area_Icons_Settings.reg
    Download
    3. Save the .reg file to your desktop.
    4. Double click/tap on the downloaded .reg file to merge it.
    5. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve merging.
    6. Log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Enable or Disable "Notification Area Icons" Settings in Group Policy
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Start Menu and Taskbar. (see screenshot below)
    3. In the right pane, double click/tap on Turn off notification area cleanup to edit it. (See screenshot above)
    4. To Enable the Ability to Change "Notification Area Icons"
    A) Select (dot) either Not Configured or Disabled, and go to step 6 below.. (see screenshot below step 6)
    5. To Disable the Ability to Change "Notification Area Icons"
    A) Select (dot) Enabled, and go to step 6 below.. (see screenshot below step 6)
    6. Click/tap on OK. (see screenshot below)
  1. Posts : 3,612
    great Tutorial as always brink :)
  2. Posts : 72,051
    Thank you sir. :)
  3. Posts : 1
    Window 10 Pro X64
    Command-line utility to hide or make visible systray icons
    https://hianz.wordpress.com/2013/09/...nager-is-here/
    This fellow created a C Command-line utility with a companion dll, one for Windows 7 one for Windows 10.
    It is simple and elegant, it hides or makes visible a single icon in the system tray notification area. Source code available there as well. I have tested it on both Windows 7 and Windows 10 and it worked as advertised.
    It also helps you find what you need on the command-line. Brilliant!
