Taskbar - Resize
    Taskbar - Resize
    Taskbar - Resize
    How to Resize the Taskbar in Vista and Windows 7
    This will show you how to resize the taskbar by changing it's height or width on the desktop in Vista and Windows 7.
    Here's How:
    1. Unlock the taskbar.
    2. Move and hover the mouse pointer over the top or side border of the taskbar until it turns into a double arrow. (see screenshots below)
    3. Left click and hold, drag the taskbar to the level for how high or wide you would like it to be, then release left click when finished. (see screenshots below)
    4. Lock the taskbar.
  1. Posts : 30
    win 7 64 home premium
    nope
    nope, only doubles it or not...cannot make it any size you want.
  2. Posts : 72,041
    Yep, it changes the taskbar width or height by any level you like. Please try again.
  3. Posts : 30
    yeah, tried it again...no go...i am sure there are other settings involved that dont allow me to do that. i am kind of a nut for settings and just cant figure that out. but thanks anyway.
  4. Posts : 72,041
    Are you saying that when you unlock the taskbar and keep dragging it up, you are not able to increase it's height one level at a time to say double, triple, quadrouple it's default one level height?
    I find it hard to believe if you are not able to.
  5. Posts : 30
    ah yes, i can do that, but the problem is the taskbar is too big now and i can only get it to about 3/4 inch high and that is as small as i can move it. my icons look way out of place as they are so small.
  6. Posts : 72,041
    OK. How does it look using large icons instead of small?
    Taskbar - Use Small or Large Icons
