Taskbar - Resize - Enable or Disable
    How to Enable or Disable Resizing the Taskbar in Vista and Windows 7
    This will show you how to enable or disable the ability of users from resizing the taskbar in Vista and Windows 7.
    You must be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: Resizing the Taskbar
    NOTE: When disabled, you will no longer get the double arrow mouse pointer to be able to drag the taskbar border.
    Taskbar - Resize - Enable or Disable-resize-1.jpgTaskbar - Resize - Enable or Disable-resize-2.jpg
    OPTION ONE
    Using a REG File Download
    NOTE: This option will affect all users on the computer.
    1. To Enable the Ability to Resize the Taskbar
    Enable_Taskbar_Resize.reg
    B) Go to step 3.
    2. To Disable the Ability to Resize the Taskbar
    Disable_Taskbar_Resize.reg
    Download
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes (UAC-Windows 7) or Continue (UAC-Vista), Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, and Start Menu and Taskbar. (see screenshot below)
    3. In the right pane, right click on Prevent users from resizing the taskbar and click on Edit. (See screenshot above)
    4. To Enable the Ability to Resize the Taskbar
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    B) Go to step 6.
    5. To Disable the Ability to Resize the Taskbar
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click on OK. (see screenshot below)
    8. Log off and log on, or restart the computer to apply.
  1. Posts : 8,398
    Great tutorial, Shawn. Well done. :) I remember the old XP days though, when you could just click 'n' drag...
  2. Posts : 72,043
    Thank you sir. It's pretty much the same way though. :)
