Windows 7: AHCI Link Power Management - Enable HIPM and DIPM
04 Apr 2016   #10
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by notis View Post
Thanks for tutorials Brink.
I merge the Add "AHCI Link Power Management-HIPM/DIPM" .reg but I could not get the power options. Looking in the registry I found the key with attribute dword ...2
I'm speaking for Dell xps sata3 ahci. Any idea? Do you advice maybe to remove it?
Hello notis,
Double check the red warning box at the top of the tutorial to see if anything may apply.
If everything checks out, then you might see if restarting the computer may help.
04 Apr 2016   #11
Windows 7 Home Premium x64, *W7 Prem. x64
Thanks for quick reply. I've done both.
I'm with two h.disks. First is a SSD Samsung (a clean install). Second WDC WD7500BPKX which is a clone restore with Macrium.
Both with an Os W7. In Bios Ahci enable but it doesn't show if is for both. Can it be only for one of them?
I was trying to enable the power option in the second disk (WDC) for testing performance.
Unfortunately at this moment I don't know if it support Himp/Dimp.
If I let the key with attribute ....2 what exactly it means? Is it okey to let it even if is not showing as an option in Power options? Thanks
04 Apr 2016   #12
It won't hurt anything to leave it enabled (set to 2) if you like.
You might see if merging the .reg file again may help in case one of the approval prompts wasn't approved by you by mistake.
04 Apr 2016   #13
Ok. you are right. There are bigger problems than this in life..
Maybe you know if the dword value is 1 or 0 what it brings?
Anyway... Have a good time... and thanks (again..)
04 Apr 2016   #14
1 = off
2 = on
04 Jun 2016   #15
Does this work on Windows 10?
04 Jun 2016   #16
Quote   Quote: Originally Posted by HoneycombAG View Post
Yes. It'll be the same in Windows 10.
Tutorial Tools Search this Tutorial
Search this Tutorial:
Advanced Search
Windows 7 Tutorial Category
Enable and/or Disable AHCI
I hope I am not duplicating something here. . . . I did look - Honest! I ran into an interesting problem and found an easy fix. First: I wanted to ENABLE AHCI because (supposedly) it improves HDD performance. (It also enables a host of other interesting features.) I discovered the...
Hardware & Devices
PCIe Link State Power Management - Turn On or Off in Windows
How to Turn On or Off PCIe Link State Power Management in Windows The Link State Power Management is a part of PCI Express Active State Power Management (ASPM). The link State of a PCIe Device is converted from L0 (on) to L1 (off) when the link is not transferring data. The hardware is...
AHCI : Enable in Windows XP after OS install
For info on other OS's take look here: You can use this method on Legacy BIOS or uEFI/BIOS firmware. For this example I am using a PC with uEFI/BIOS firmware & Secure Boot DISABLED. With a Intel Chip Set. ...
enable AHCI in Windows 7
hi... i found several tutorials to enable the AHCI-driver in win7/vista but the registry keys don't match mine... the tutorial is as following: 1. Exit all Windows-based programs. 2. Click Start, type regedit in the Start Search box, and then press ENTER. 3. If you receive the User Account...
Hardware & Devices
Windows 7...>SSD....Enable AHCI B4 Installation
Okay I plan on doing a clean install of Windows 7 on my laptop. I have an SSD from crucial. I know that I need to enable AHCI BEFORE I start the installation of Windows 7...correct? Now....I saw this Intel website in regards to AHCI. Intel® Rapid Storage Technology — Configure the...
Installation & Setup
AHCI to Enable or Not?
Hi, I am using a HP Pavillion 180t computer with Window 7(SP-1), IE9 RC. 12GB Ram, Quad Core i7, 3.33Ghz. I do not have AHCI enabled based upon the Tutorial to do so. Would enableing AHCI be of value to me? If so how? Any help appreciated.
Performance & Maintenance
