Windows 7: AHCI Link Power Management - Enable HIPM and DIPM
4 Weeks Ago   #20
Brink
64-bit Windows 10 Pro
It looks like you are already using AHCI, so you should be good to go once you add the setting to Power Options.
Personally, I've found that the default settings usually work great.
4 Weeks Ago   #21
chrisbd27
Microsoft Windows 7 Home Premium 32-bit 7601 Multiprocessor Free Service Pack 1
Thank you brink. is there any other settings like this? and whats your opinion HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\explore.exe\UseLargePages\PerfOptions\CpuPriorityClass,IO Priority,Page Priority? i heard these setting are good gaming tweaks and that it beats process lasso?
4 Weeks Ago   #22
Brink
I haven't used any of those tweaks to say.
4 Weeks Ago   #23
chrisbd27
Oh alright well thank you brink and keep up the good work
Enable and/or Disable AHCI
I hope I am not duplicating something here. . . . I did look - Honest! I ran into an interesting problem and found an easy fix. First: I wanted to ENABLE AHCI because (supposedly) it improves HDD performance. (It also enables a host of other interesting features.) I discovered the...
Hardware & Devices
PCIe Link State Power Management - Turn On or Off in Windows
How to Turn On or Off PCIe Link State Power Management in Windows The Link State Power Management is a part of PCI Express Active State Power Management (ASPM). The link State of a PCIe Device is converted from L0 (on) to L1 (off) when the link is not transferring data. The hardware is...
Tutorials
AHCI : Enable in Windows XP after OS install
For info on other OS's take look here: http://www.sevenforums.com/tutorials/61869-ahci-enable-windows-7-vista.html You can use this method on Legacy BIOS or uEFI/BIOS firmware. For this example I am using a PC with uEFI/BIOS firmware & Secure Boot DISABLED. With a Intel Chip Set. ...
Tutorials
enable AHCI in Windows 7
hi... i found several tutorials to enable the AHCI-driver in win7/vista but the registry keys don't match mine... the tutorial is as following: 1. Exit all Windows-based programs. 2. Click Start, type regedit in the Start Search box, and then press ENTER. 3. If you receive the User Account...
Hardware & Devices
Windows 7...>SSD....Enable AHCI B4 Installation
Okay I plan on doing a clean install of Windows 7 on my laptop. I have an SSD from crucial. I know that I need to enable AHCI BEFORE I start the installation of Windows 7...correct? Now....I saw this Intel website in regards to AHCI. Intel® Rapid Storage Technology — Configure the...
Installation & Setup
AHCI to Enable or Not?
Hi, I am using a HP Pavillion 180t computer with Window 7(SP-1), IE9 RC. 12GB Ram, Quad Core i7, 3.33Ghz. I do not have AHCI enabled based upon the Tutorial to do so. Would enableing AHCI be of value to me? If so how? Any help appreciated.
Performance & Maintenance
