Windows 7: System Info - See Your System Specs
11 Aug 2011   #109
Brink
64-bit Windows 7 Ultimate SP1 & Windows 8 Enterprise
Texas
How to See Your System Specs with "System Info"
06 Jun 2012   #110
vvinushan
Windows 7 Ultimate 32bit SP1
Not showing any specs
Hello Brink, I am new to this forum and I am trying to fill in my system specs. Whenever I open the program, it says 'Invalid Class See contacts in Help - About menu'. I checked in Help and there was only About system info. Please can you help as I was going to post my first thread and wanted to fill in system specs before that. Thank you.
System Info - See Your System Specs-capture.png   System Info - See Your System Specs-capture2.png
06 Jun 2012   #111
Brink
Texas
Hello Vinush, and welcome to Seven Forums.
Do you have all of your Windows Updates installed?
You might also see if right clicking on it and using Run as administrator may help.
Hope this helps for now until the program developer may be able to help further if needed.
06 Jun 2012   #112
vvinushan
I have installed all my updates and run the program as an administrator. I am still getting the same error message.
06 Jun 2012   #113
Brink
Texas
Ok. I sent a message for the developer to take a look when he's able to. Hopefully soon for you.
01 Jul 2012   #114
DavidW7ncus
Win 7 Pro x64 SP1, Win 7 Ult x86 SP1
NC, USA
Are there any requirements for what "Net Framework" is needed for SystemInfo.exe ?
Here is a thread i helped with, and it seems like it, but i'm just guessing ...
http://www.sevenforums.com/drivers/2...-driver-2.html
Thanks,
David
01 Jul 2012   #115
Brink
Texas
Hello David,
I believe that the developer CyberZeus had updated this a while back to where the default Net Framework should be all that's needed now. You might check to make sure that they have all of their Windows Updates installed for this to see if it may help.
01 Jul 2012   #116
DavidW7ncus
NC, USA
Hi Shawn,
Thanks, i appreciate it
I posted the question to the OP/thread with the lan driver issue.
Maybe this more of a question for CyberZeus ?
If someone is current with Windows updates, is it possible they might not have any NET Framework installed?
If they don't, should they get prompted to install NET framework for this...?
Thanks !
David
edit: found out windows updates were not current...
01 Jul 2012   #117
Brink
Texas
Yeah CyberZeus would be best for the program itself.
By default, Net Framework 3.5 is included in Windows 7, and is updated to 4 through Windows Update unless Net Framework was turned off in Windows Features.
EDIT:
Ah, perfect. Glad it is working for them now.
29 Jul 2012   #118
boing
WNC, USA
Great work. This forum never ceases to amaze me.
Is there a preferred place in one's profile for adding the system specs for a second computer? I know I'll have to add it manually, I just want to make sure I put it where helpful folks might tend to look.
29 Jul 2012   #119
Golden
Windows 7 Ultimate SP1 (x64)
South Australia
Nope, you can add it in wherever you like - and welcome to SevenForums.
Regards,
Golden
Comment
 System Info - See Your System Specs problems?
Tutorial Tools
Similar help and support threads for: System Info - See Your System Specs
Windows 7 Tutorial Category
Solved Where do i find the info for my system specs? General Discussion
System Image info, shadow/system restore storage - internal workings Backup and Restore
Solved System Specs Customization
System Specs General Discussion
