Windows 7: System Info - See Your System Specs
19 Dec 2012   #130
Dwarf
Windows 8.1 Pro RTM x64
Yep, they're there.
10 Aug 2013   #131
AaLF
Gentlemen, could someone check the system info link. Can't seem to dload it.
10 Aug 2013   #132
bobafetthotmail
Win 7 Pro 64-bit 7601
it works for me. I can download the tool.
10 Aug 2013   #133
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by AaLF View Post
Hello AaLF,
Your AV program may be blocking the download since it's an .exe file. I added a ZIP download option to see if that may work better for you.
26 Aug 2013   #134
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Thanks for the Tutorial/ Added to my signature
Worked great by the way,
Except for a few sections/ Case-pcu-cooling ?
Cheers.
18 Feb 2014   #135
kiltylyn
thanks a lot
20 May 2014   #136
fmb419
windows 7 home premium 64bit
Can't run SystemInfo.exe
When I download and try to run SystemInfo.exe I get "Fatal error CLR error 8004005.
What am I doing wrong?
Frank
20 May 2014   #137
Brink
Hello Frank, and welcome to Seven Forums.
Usually this error is related to .NET Framework.
Run a sfc /scannow command to see if you have any issues with corrupted system files, and if SFC can repair them if so. After SFC has sorted any issues, see if you are able to run the file.
22 Jun 2014   #138
win7jak
Windows 7 Ultimate Service Pack 1
Didnt work for me...all windows are blank using Firefox 30
22 Jun 2014   #139
Brink
Hello Win7jak,
Did you use step 5 if you wanted to do it automatically?
Otherwise, it'll just open your edit specs settings here at SF in your default browser when you only click on the Edit System Spec link in the System Info program.
Hope this helps.
Processor info is showing wrongly in system info after changing MB
Yesterday I bought a new mother board for my PC my Processor model is AMD Athlon II X3 440 Triple Core Processor, but after changing Mother Board in system information it's showing my Processor as AMD Phenom II 4 B40 four core processor. I don't know why it is showing like this. Is this dangerous...
Hardware & Devices
Where do i find the info for my system specs?
Uhmm hello, Lol just a compter noob talking, but uhm.. where can I find the info for the system specs fields?
General Discussion
System Specs
Hi everybody. OK, stop booing or I'll send Marion my Predator after you. Here's my problem...... one of my problems. I am trying to fill in all my system specs. I have used, with some success, the tutorial here on SF and been able to fill in some specs. Others, I knew and was able to fill in...
Customization
