Windows 7 Forums Search
Windows 7 - System Info - See Your System Specs
How to See Your System Specs with "System Info"
Published by Brink
08-11-2011
Default System Info - See Your System Specs
information   Information
System Info is free Seven Forums program that CyberZeus has kindly made for us. It let's you easily see all of your system information to make filling out your system specs here at Seven Forums easier to do.
Here's How:
1. Click on the Download button below to download and save the SystemInfo.exe file to your desktop.
download
2. Run the SystemInfo.exe file.
NOTE: This is a standalone .exe file that only runs and does not install anything on your computer. If you would like to stop getting the Run prompt, then unblocking the SystemInfo.exe file will stop it.
3. After System Info loads, you will see a summary of your system's information.
NOTE: There's a Edit System Specs link at the bottom right that will take you to your system specs here at Seven Forums.
4. Clicking on each device icon will give you a pop-up with more detailed information about that device.
System Info - See Your System Specs-cpu.jpgSystem Info - See Your System Specs-motherboard.jpg
System Info - See Your System Specs-bios.jpgSystem Info - See Your System Specs-memory.jpg
System Info - See Your System Specs-hard_disk.jpgSystem Info - See Your System Specs-logical_disk.jpg
System Info - See Your System Specs-sound_card.jpgSystem Info - See Your System Specs-graphics.jpg
System Info - See Your System Specs-network.jpgSystem Info - See Your System Specs-os.jpg
5. Do either step 6 or 7 below for how you would like to fill out your system specs at Seven Forums.
6. To Manually Fill Out your System Specs at Seven Forums
A) In System Info, click on Options (menu bar), Settings, select (dot) Manual Mode, and click on OK. (see screenshots below)
Click image for larger version
ID:	198013Name:  Options_Settings.jpg
B) Click on the Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
C) You can now use the information in System Info to fill out your system specs at Seven Forums by clicking on the Name:  Copy_to_Clipboard.jpg
Size:  1.1 KB button to the right of a system spec in System Info to copy it to the clipboard, then right click in a system specs field at Seven Forums like below and click on Paste. When finished filling out your system specs, be sure to click on the Save Changes button at the bottom to save them.
7. To Automatically Fill Out your System Specs at Seven Forums
NOTE: This step can only be done using Internet Explorer.
A) In System Info, click on Options (menu bar), Settings, select (dot) Automatic Mode, and click on OK. (see screenshots below)
C) If you are not already, log in to Seven Forums in the new IE Seven Forums' Site window that just opened. (see screenshot below)
D) Click on the Set info button at the top left corner to automatically enter the information from System Info into your system specs at Seven Forums, then click on the Save Changes button at the bottom to save them. (see screenshot below)
Brink's Avatar
Administrator
Tutorial Tools
08-11-2011   #1
derekimo
Windows 7 Pro 64 SP1
Nice explanation Shawn, I noticed on the tool itself it will take you right to your system specs if you click on edit system specs at the bottom.
Handy tool CyberZeus.
08-11-2011   #2
Layback Bear
windows 7 home premium 64/SP1
Thank you Mr. Brink. Nice little tool.
08-11-2011   #3
CyberZeus
Windows 7 Ultimate x64 SP1 clean install
Perfect explanation Brink!
I could never do it better!
08-11-2011   #4
boohbah
Edited system spec using the tool, thanks cyberzeus and brink.
08-11-2011   #5
StalkeR
Windows 7 Ultimate SP1 x64
Great !
08-11-2011   #6
CyberZeus
Quote   Quote: Originally Posted by boohbah View Post
You're welcome!
08-11-2011   #7
FredeGail
Microsoft Windows 7 Ultimate: x64 (SP1)
Nice design I have to say.
Best Regards,
FredeGail
08-11-2011   #8
MvdB
Windows 7 64b Ultimate
Great tool, great explanation! Well done to both!
08-12-2011   #9
Dave76
Windows 7 Ult x64 - SP1/ Windows 8 CP x64
Another great tut, thanks Brink.
Great app, thanks CyberZeus for taking the time to make it.
Comment
 System Info - See Your System Specs problems?
Tutorial Tools
Similar Threads for: System Info - See Your System Specs
Windows 7 Tutorial Category
System Image info, shadow/system restore storage - internal workings Backup and Restore
System Specs for Win 7 General Discussion
System Specs General Discussion
