| Windows 7: System Info - See Your System Specs System Info - See Your System Specs How to See Your System Specs with "System Info"
Published 11 Aug 2011
|  Published by | | |
 Featured Tutorial | | | How to See Your System Specs with "System Info"  Information System Info is free Seven Forums program that CyberZeus has kindly made for us. It let's you easily see all of your system information, and has an option to make filling out your system specs here at Seven Forums easier to do. Here's How:1. Click on the Download button below to download and save the SystemInfo.exe file to your desktop. 2. Run the SystemInfo.exe file. NOTE: This is a standalone .exe file that only runs and does not install anything on your computer. If you would like to stop getting the Run prompt, then unblocking the SystemInfo.exe file will stop it. 3. After System Info loads, you will see a summary of your system's information. NOTE: There's a Edit System Specs link at the bottom right that will take you to your system specs here at Seven Forums. 4. Do either step 5 or 6 below for how you would like to fill out your system specs at Seven Forums. 5. To Automatically Fill Out your System Specs at Seven Forums NOTE: This step can only be done using Internet Explorer.A) In System Info, click on Options (menu bar), Settings, select (dot) Automatic Mode, and click on OK. (see screenshots below)  B) Click on the Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
C) If you are not already, log in to Seven Forums in the new IE Seven Forums' Site window that just opened. (see screenshot below)
D) Click on the Set info button at the top left corner to automatically enter the information from System Info into your system specs at Seven Forums, then click on the Save Changes button at the bottom to save them. (see screenshot below)
6. To Manually Fill Out your System Specs at Seven ForumsA) Clicking on each device icon will give you a pop-up with more detailed information about that device.          B) In System Info, click on Options (menu bar), Settings, select (dot) Manual Mode, and click on OK. (see screenshots below)  C) Click on the Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
D) You can now use the information in System Info to fill out your system specs at Seven Forums by clicking on the button to the right of a system spec in System Info to copy it to the clipboard, then right click in a system specs field at Seven Forums like below and click on Paste. When finished filling out your system specs, be sure to click on the Save Changes button at the bottom to save them.
| | | Need more help? Try searching our extensive help and support site.
Loading | |
11 Aug 2011
Nice explanation Shawn, I noticed on the tool itself it will take you right to your system specs if you click on edit system specs at the bottom.
Handy tool CyberZeus. | My System Specs |
| Computer type PC/Desktop System Manufacturer/Model Number Compaq sr5410f case OS Windows 7 Pro 64 SP1 CPU AMD X2 4450E @ 2.3 ghz Motherboard Biostar MCP6P M2+ Memory 4.0 g Graphics Card Nvidia GeForce 9600 GT , 512mb Sound Card onboard Monitor(s) Displays auria eq2367 Screen Resolution 1920 x 1080 Keyboard logitech wave cordless Mouse logitech LX8 cordless laser mouse PSU 250 watts Case Compaq Cooling couple fans Hard Drives 1 tb Hitachi HDT721010SLA scsi, 500 gb external Internet Speed comcast hi speed 19 dn 8 up Antivirus Microsoft Security Essentials Browser IE10 Other Info Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Microsoft Windows 7 Professional 64-bit 7601 Multiprocessor Free Service Pack 1 |
11 Aug 2011
Thank you Mr. Brink. Nice little tool. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Home made Desktop OS Windows 7 Home Premium 64 bit. SP-1 CPU Intel i7-960-3.2 @ 4.25 Motherboard ASUS P6X58D-E Memory KINGSTON KHX2000C9, Hyper X,12 GIGS Graphics Card MSI/Nvidia/460GTX-Cyclone 1GD5/OC Monitor(s) Displays DYNEX 40 IN. Screen Resolution 1920-1080 or 1280-720 HDMI Keyboard M/S 3000 v 2.0 wireless Mouse M/S 5000 wireless PSU Corsair AX-850 Plus Gold Case Corsair 600T (Black) + side panel with 2 140 mm Noctua fans Cooling Corsair H50/2 Noctua NF-P12 (120 mm) Push/Pull- Hard Drives INTEL SSD 120GB-SER 510
Seagate 1TB SATA 600 7200 rpm Hard Drive Internet Speed 3.0 mb Antivirus Microsoft Security Eesentials Browser I.E. 10 default/Firefox Other Info LG BluRay-Read/Write
Sound system
KLipsch-THX
Asus Router RTN-12
2 Noctua 140 added on top of 600t case
Malwarebytes Anti Malware Professional
Windows 7 Firewall |
11 Aug 2011
Perfect explanation Brink!
I could never do it better! | My System Specs | | System Manufacturer/Model Number Custom Build OS Windows 7 Ultimate x64 SP1 clean install CPU AMD Athlon 64 X2 6400+ Motherboard Asus M2N-E SLI Memory 4 GB Graphics Card 2 x NVidia Geforce 8600 GTS Sound Card Trust 5.1 Surround USB Monitor(s) Displays Benq FP931 19" Screen Resolution 1280x1024@32bit@75MHz Keyboard Logitech Cordless Desktop EX 100 Mouse Logitech Cordless Optical PSU 650W Hard Drives 1 x Western Digital 500GB SATA (OS installation), 2 x Seagate 320GB SATA, 1 x Seagate 250GB IDE (in external USB box), 1 x TrekStor 750GB USB Internet Speed 8192 kbps / 640 kbps |
11 Aug 2011
Edited system spec using the tool, thanks cyberzeus and brink. | My System Specs | | System Manufacturer/Model Number Hewlett packard/p6512uk OS Microsoft Windows 7 Home Premium 64-bit 7600 CPU IIx4 amd athelon 635 processor Motherboard FOXCONN 2AA9 Memory 2x2gb Graphics Card ati radeon HD 5450 Sound Card (1) Realtek High Definition Audio (2) AMD High Definition Monitor(s) Displays samsung lcd tv 32" Screen Resolution 1360x 768 Keyboard wireless hp Mouse wireless Hp,optical PSU ? Cooling air! Hard Drives (1) WDC WD10 01FAES-60Z2A0 SATA Disk Device (2) Maxtor OneTouch USB Device (3) ST310003 33AS USB Device (4) WD My Book 1111 USB Device Internet Speed 1.10mb/s Antivirus MSE Browser Firefox |
11 Aug 2011
Great ! | My System Specs | | OS Windows 7 Ultimate SP1 x64 CPU Intel Pentium G630 @2.7GHz 3MB Motherboard Asus P8H61-M LX3 PLUS Memory Corsair 4GB DDR3 / 1066MHz 9-9-9-24 2T Graphics Card Intel HD Graphics Sound Card Integrated Monitor(s) Displays Philips 192EL Screen Resolution 1366 x 768 Keyboard Delux K5108 Mouse Genius PSU Hantol 500W Case Delux costumized... Cooling 120mm Hantol, Spire 80mm Hard Drives WD Caviar Blue 500GB / 16MB Internet Speed 15 Mbit Other Info Genius SW-2.1 355 Speakers,Camera,Joystick
Asus K55VJ(i5 3210, GT635M / 2GB, 8GB DDR3, 500GB HDD) |
11 Aug 2011
Quote: Originally Posted by boohbah Edited system spec using the tool, thanks cyberzeus and brink. You're welcome! | My System Specs | | System Manufacturer/Model Number Custom Build OS Windows 7 Ultimate x64 SP1 clean install CPU AMD Athlon 64 X2 6400+ Motherboard Asus M2N-E SLI Memory 4 GB Graphics Card 2 x NVidia Geforce 8600 GTS Sound Card Trust 5.1 Surround USB Monitor(s) Displays Benq FP931 19" Screen Resolution 1280x1024@32bit@75MHz Keyboard Logitech Cordless Desktop EX 100 Mouse Logitech Cordless Optical PSU 650W Hard Drives 1 x Western Digital 500GB SATA (OS installation), 2 x Seagate 320GB SATA, 1 x Seagate 250GB IDE (in external USB box), 1 x TrekStor 750GB USB Internet Speed 8192 kbps / 640 kbps |
11 Aug 2011
Nice design I have to say.
Best Regards,
FredeGail | My System Specs | | System Manufacturer/Model Number Brewed OS Microsoft Windows 7 Ultimate: x64 (SP1) CPU Intel® Core™ i5-2500K Processor Motherboard ASUS P8Z68-V PRO Memory Kingston DDR3 HyperX 1600MHz 8GB Graphics Card ASUS GTX 560 TI DirectCU II 900MHz Sound Card Realtek® ALC892 8-Channel High Definition Audio CODEC Monitor(s) Displays ACER LCD P246HBD 1920x1080 (24") - Dell 1280x800 Screen Resolution ACER LCD P246HBD ~ [1920X1080] - DELL ~ [1280x800] Keyboard Logitech G15 Mouse Coolermaster Sentinel Advanced PSU Corsair 750W Power Supply Case Coolermaster CM Scout Cooling Zalman FS-C77 Fatal1ty CPU Cooler Hard Drives 500 GB WD Caviar SE116 7200rpm SATA2 Internet Speed [↓ 10 MB/s DL] [↑ 1 MB/s UL] Other Info - ROCCAT™ Kave – Solid 5.1 Surround Sound Gaming Headset
- Not overclocking |
11 Aug 2011
Great tool, great explanation! Well done to both! | My System Specs | | System Manufacturer/Model Number custom build OS Windows 7 64b Ultimate CPU I7-2600 3.40GHz - testing various OC levels.. Motherboard ASUS Sabretooth Memory 2x 4Gb DDR3/1333 Graphics Card GTX570 - testing OC levels Sound Card motherboard 7.1 DIG. Monitor(s) Displays 2x Ilyama 24" E2409HDS-B1 2ms/DVI Screen Resolution 1920 x 1080 Keyboard Logitech G110 Mouse Logitech G700 PSU Corsair Pro HX850W Cooling Coolermaster Hyper V8 Hard Drives 120 GB Intel Elmcrest SSD
1 TB SATAII 7200RPM/32MB
External 2TB USB3 Internet Speed 25Mb Other Info CPU: 7,7 RAM: 7,7 GTX: 7,9 GTX 3D : 7,9 SSD 7,6
Overall 7,6 ...... now to speed up the SSD... ;)
Also use a Dell XPS M1710 on Vista 32b
Asus LT on Vista 32
3 older machines still doing fine on Linux/ubuntu but not used much anymore... |
12 Aug 2011
Another great tut, thanks Brink.
Great app, thanks CyberZeus for taking the time to make it. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number 76~2.0 OS Windows 7 Ult x64 - SP1/ Windows 8 Pro x64 CPU Intel Core i5-3570K 4.6GHz Motherboard Gigabyte GA-Z77X UD3H, f18 Memory 8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5v Graphics Card Sapphire HD 7770 Vapor-X OC 1GB DDR5 Sound Card Onboard VIA VT2021 Monitor(s) Displays 22" LCD Dell Screen Resolution 1680x1050 Keyboard Logitech Wave Mouse CM Sentinel PSU Corsair HX650W Case Cooler Master Storm Scout Cooling Corsair H80 2x12cm Noctua NF P12 , 2x14cm case fans Hard Drives Samsung 840Pro 128GB SSD,
Seagate Barracuda 500GB SATA2 7200rpm 32MB cache, Seagate Barracuda 1TB SATA2 7200rpm 32MB cache, Internet Speed Dismal Antivirus Avast Browser Opera Next Other Info eSATA ports,
External USB WD 500GB System Info - See Your System Specs problems? All times are GMT -5. The time now is 08:26 PM. | |
