Windows 7: Internet Troubleshooting Guide
Dinesh's Complete Internet Troubleshooting Guide
Published by Dinesh
25 Jul 2009
information   Information
This is your one-stop internet related issues guide. Here I will show you some ways to fix your high speed or dial up internet connection issues with Windows 7.
Note   Note
I will show you some very useful and basic steps that you can follow without having much technical expertise. All you have to do is identify your issue and follow the troubleshooting according to it.
warning   Warning
I do not guarantee that it will 100% work for you. However, these methods have been tried and tested and has worked 8/10 times. So try your luck.
Here's How:
Step 1: Identify your internet connection:
A: Do you have a high speed connection or a dial-up connection?
  • If you use a telephone line and connect it to your computer and dial the connection, you have a dial-up connection.
  • If you have a router or a cable/DSL modem with an ethernet cable connected to your computer, its a high speed connection.
Step 2: Troubleshoot the issue.
Note   Note
To fix internet issues related to high-speed connection, follow these steps:
When you Cannot Connect to internet using a high-speed or broadband cable connection.
Check your IP Address.
Click Start and in the Start Search box, type cmd and press Ctrl+Shift+Enter.
Now in the black command prompt window, type ipconfig /all
(See the screen-shots below).
Look for Ethernet Adapter Local Area Connection.
Look for IPV4 Address. If its anything other than 169.254.xxx.xxx, you have a valid IP address.
For any other ip address other than 169.254.xxx.xxx, follow these steps:
Now that you've diagnosed that you have a valid IP address, its time to diagnose the issue.
A: In the same black command prompt window, type
ping <Default Gateway> and press Enter.
(See the screenshot below).
Now look at the ping statistics, it should send 4 packets and receive 4 packets. Sent=4, Received=4, Lost=0.
B: If the ping is successful, type
ping Google and press Enter.
(You can type the address of any website like Yahoo! to check the connectivity).
If the ping is again successful, your Anti virus or firewall program is blocking your internet connection. By pinging Default Gateway and websites, we check the internet connectivity of the computer with ISP and websites respectively.
Now that you've diagnosed that the ping is successful, its time to troubleshoot the issue.
  • If ping to Default Gateway and website is successful but you cannot browse any websites:
Temporarily disable/remove your antivirus program and your internet will start working.
Note: You can also boot to safe mode with networking to check the internet connectivity. (Press F8 when you turn on your computer and select Safe mode with networking option to boot the computer to safe mode with networking).
  • If ping to Default Gateway is successful but pinging websites returns an error and you cannot browse any websites:
In the same black command prompt window, type the following commands and press Enter after each command:
Ipconfig /flushdns
Ipconfig /release
Ipconfig /renew
Now restart your computer and try to browse to some websites like yahoo,google, etc.
  • If ping to Default Gateway and pinging websites returns an error and you cannot browse any websites:
Note   Note
If you ping the default gateway or any website, you may get an error saying “Media State Media Disconnected” and ping will not return you any statistics
A: Check whether your internet cable is properly plugged in to the computer.
B: Remove the internet cable from computer, restart your cable modem and computer and plug the internet cable back to the computer.
C: Verify whether all the lights on the cable modem are lit.
D: Enter BIOS, make sure that the Integrated NIC is Not Disabled.
E: In the black command prompt window, type
Ipconfig /release and press Enter. Then type ipconfig /renew to obtain a new ip address from the DHCP server.
F: Click Start and in the Start Search box, type services.msc and press Enter. Then double-click DHCP client service and make sure the Startup type is Automatic and Status is Started.
If ping to Default Gateway is successful but pinging any website is unsuccessful and you cannot browse any websites:
(Ping Statistics: Sent=4, Received=0, Lost=4. )
A: Temporarily disable/remove your antivirus or firewall program.
B: Try a system restore.
C: Delete all temp files and cookies and restart your computer and cable modem.
D: If you have connected your computer to a router, bypass the router and connect the computer directly to the cable/DSL modem.
For ip address 169.254.xxx.xxx, follow these steps:
A: In the command prompt window, type
netsh winsock reset catalog and press Enter. Now restart your computer.(See the screenshot below).
C: Click Start and in the Start Search box, type services.msc and press Enter. Then double-click DHCP client service and make sure the Startup type is Automatic and Status is Enabled.
D: Remove the internet cable from computer, restart your cable modem and computer and plug the internet cable back to the computer.
E: Reinstall Windows 7.
Note   Note
To fix internet issues related to dial-up connection, follow these steps:
When you Cannot Connect to internet or cannot dial a connection using a dial-up connection.
A: Check your telephone line and make sure its connected properly to the modem port at the back of the computer.
B: Lift the telephone receiver and listen to the dial tone to make sure that the telephone line is working.
C: Check the connection properties by clicking on Start>Control Panel\All Control Panel Items>Phone and Modem.
Under Phone and Modem>Dialing Rules>My Location>Edit make sure that the Country/Region and the Area Code is matching with yours.
D: Click Start and in the Start Search box, type msconfig and press Enter.
In the system configuration utility, click Startup and click Disable All.
Click Apply and Click on Ok and Click Restart now.
E: Delete temp files and cookies by using this tutorial.
F: Call your ISP to reset your account.
G: Open the computer and Reseat the modem card or put it in a different slot.
H: Reinstall Windows 7.
I: Replace the modem card (Hardly costs US$20).
Note   Note
If your internet stopped working after a thunderstorm or lightening, directly proceed to Step G.
Note: Make sure you install the latest NIC driver for high speed internet connection.
Hope this helps you getting online once again,
Dinesh.
26 Jul 2009   #1
mickey megabyte
ultimate 64 sp1
nice tutorial dinesh.
a few months ago i had intermittent connection problems after a particularly bad thunderstorm, and it took me a few days to track the fault to my DSL filter. i replaced it, and everything has been groovy since then.
26 Jul 2009   #2
Dinesh
Windows® 8 Pro (64-bit)
Quote   Quote: Originally Posted by mickey megabyte View Post
Thanks mate. I m glad to hear that you sorted it out by replacing the faulty hardware.
27 Jul 2009   #3
cvk1952
Internet connection problems
Hallo everybody.
I am using Windows 7 64 bit version connected to an High speed connection.
The sytem did install 2 differend programm directories, one 32 bit and one 64 bit.
Also two IE8 versions.
The IE 8 64 bit version works fine.( and fast like H....ll )
The IE 8 32 bit does not connect to the internet.( Not at all)
I did check all settings and as far as I can see they are all the same.
Non of my 32 bit programms can enter internet and the system does not allow me to copy all the 64 bit files over the 32 bit files.
If I use this sample which system are I looking.
The 32 bit or the 64 bit ??
Regards Cees
27 Jul 2009   #4
Dinesh
Hi cvk, this troubleshooting applies to both 64bit and 32bit. Well yours is a wierd problem as its happening will all 32bit programs.
Also, you wont be able to copy 32bit items to 64bit program files folder. Have you tried any other browser like firefox?
27 Jul 2009   #5
cvk1952
Hi, dinesh.
I did try to copy my programm files to the 64bit area.
Same result. Somehow these 32 bit programms are directed to the 32bit browser.
I did try every combination with directories ect.
What I do not like in this --- is that I am not in controle of my programm.
It is not possible to delete EI 8 32bit. I do not have permission.
What ever I try the "SYSTEM" does not let me change/move or delete the IE 8 32bit system.
This 32bit strugel is maybe the case of HOMENETWORK not willing to work.
I do get an error but if I let W7 look for the cause it comes back with
Nothing wrong found.
I realy hope this is not a 64bit problem.
27 Jul 2009   #6
Dinesh
i guess it is a problem with the OS. I dont think its an internet issue. did you do a clean install of win7?
27 Jul 2009   #7
darkassain
Quote   Quote: Originally Posted by cvk1952 View Post
Hi, dinesh.
try all the steps again but this time use the 32 bit cmd..
(its in %windir%\SySWOW64\cmd.exe)....
01 Dec 2009   #8
Leslie
windows 7
Im gonna cry, it doesn't work for me!!!
02 Dec 2009   #9
Dinesh
Hi Leslie what is not working for you?
Need help troubleshooting internet connection - looking for tutorial
Hi, I'm needing help troubleshooting my internet connection. I was thinking there might be a troubleshooting tutorial in the archives here, but I didn't find what I was looking for. I'm thinking I might have a virus. I am currently using C-cleaner, Super-Anti Spyware, Malwarebytes, Microsoft...
Network & Sharing
Troubleshooting Internet Explorer Issues
Troubleshooting Internet Explorer Issues You might have issues with Internet Explorer like not opening or crashing often not loading pages etc. Here are few troubleshooting steps that you can do to fix certain issue. 1. The first step which always you could try is to disable the add-ons...
Tutorials
Windows Media Player Troubleshooting Guide
Windows 7 has some fine in-built diagnostic tools to help you troubleshoot Windows Media Player issues, which you may be facing. This tutorial will give you some steps to fix common problem you might encounter with Windows Media Player 12.The N and KN editions of Windows 7 have all the features...
Tutorials
troubleshooting frequent DSL internet drops
I've had DSL disconnections since early January. I've ruled out the following possible causes- * in-home wiring. I've wired up a new phone line jack with a fresh cable and 6' phone cord to the modem, and still get drops. I've unplugged the kitchen phone and its DSL filter, with no improvement. I...
Network & Sharing
Outlook - General Troubleshooting Guide for Issues
General Troubleshooting Guide For Issues with Microsoft Outlook These are some General troubleshooting steps to fix Outlook issues like unable to open or crashing while doing something in Outlook etc. 1. Start up problem of Outlook This is one of the most common problems with...
Tutorials
Internetwork Troubleshooting Guide
Full-Blown Internetwork Troubleshooting Guide Warning, This guide requires somewhat deeper knowledge in Internetworking terms. Let's start...
Tutorials
