File and Folder Arrangement - Group by - Sort by - Arrange by
Page 1 of 7 123 ... LastLast
    How to Change the Group by, Sort by, and Arrange by Folder View in Windows 7 Explorer
    This will show you how to change and organize the file and folder arrangements in a opened folder using Arrange by, Sort by, or Group by folder views in Windows 7.
       Tip
    After you make any changes to the Sort by or Group by folder view settings in a library, you can restore the library back to it's default Sort by or Group by folder view by clicking on the Arrange by drop down menu on the toolbar (top right corner) and clicking on Clear changes.
    If Clear changes is not listed, then the library is already set to be viewed by it's default Sort by or Group by folder view.
    File and Folder Arrangement - Group by - Sort by - Arrange by-clear_changes.jpg
    EXAMPLE: "Group by" and "Sort by" in Windows Explorer
    NOTE: These screenshots are using the Name column to "Group by" and "Sort by". What you see in your window will also depend on what you have the folder template and arrangement set as.
    OPTION ONE
    To Change "Sort by" and "Group by" View using the View Menu
    1. Open the Windows Explorer folder or library window that you wish to change the view of the icon sizes in.
    2. Click on the View menu bar item and select either the Sort By or Group by arrangement options, then select a column name and Ascending or Descending order for how you want the window arranged by. (See screenshots below)
    NOTE: The column names listed in the View menu bar will depend on what you have the folder template set as. You can also click on More to add more column name options.
    File and Folder Arrangement - Group by - Sort by - Arrange by-view_general_items_documents.jpg
    File and Folder Arrangement - Group by - Sort by - Arrange by-view_music.jpg
    File and Folder Arrangement - Group by - Sort by - Arrange by-view_pictures.jpg
    File and Folder Arrangement - Group by - Sort by - Arrange by-view_videos.jpg
    OPTION TWO
    To Change "Sort by" and "Group by" View using the Column Headings
    The Sort and Group option at the top, and the Stack by option at the bottom are no longer available in the final Windows 7 RTM. Please disregard them in the screenshots.
    2. To Sort by or Group by the Column Headings Name Menu
    A) Move your mouse pointer on the column headings name that you want to have the window organized by, then click on the arrow to the right of it. (See screenshots below step 3)
    B) You can now select to Sort by or Group by the window by that column headings name. (See screenshots below)
    NOTE: What you see in your window will also depend on what you have the folder template and arrangement set as.
    File and Folder Arrangement - Group by - Sort by - Arrange by-general_items_documents.jpg
    OR
    3. To Select to Organize By the Column Headings Name
    NOTE: This will allow you to quickly change what column headings name the window is organized by with still using the Sort By or Group By arrangement that you have set in step 2 or OPTION ONE above.
    A) Click on the column heading name. (See screenshots below step 2)
    NOTE: Whatever column headings name the triangle is in, is the one that the window is being organized by.
    B) Click on the same column heading name until you have the ascending or descending order that you want. (See screenshots below step 2)
    NOTE: When the triangle in the column headings name is pointing upwards, then it is descending. When the triangle in the column headings name is pointing downwards, then it is ascending.
    OPTION THREE
    To Change "Arrange by" Folder View in Libraries
    Arrange by is only available in the Library folders. The arrange by options will vary depending on the folder template of the library folder. All included folders and subfolders in a library will always share the same folder view. You are able to have separate "Arrange by" view settings in each added right click -> New -> Folder created in the library itself though.
    • The Windows Search Service must be set to Automatic and Started for this option to work.
    • Disabling the index in Windows 7 will cause you to no longer be able to use Arrange by in Libraries.
    1. Open the library folder that you wish to change the Arrange by view of the files in.
    2. Click on the View menu bar item and select Arrange by and the option for how you want the library folder files arranged. (See screenshot below)
    File and Folder Arrangement - Group by - Sort by - Arrange by-arrandeby2.jpg
    OR
    3. Click on the Arrange by toolbar option and select Arrange by and the drop down menu option for how you want the library folder files arranged. (See screenshot below)
    File and Folder Arrangement - Group by - Sort by - Arrange by-arrangeby1.jpg
    4. All included folders in the library will now have the same Arrange by set for them as well. The library will always open with the same Arrange by setting that it had when it was last closed.
  1. t41
    windows7 7600 x86
    one might note that to see the menu bar you may have to press the alt tab, since it is not on by default.
    On a temporary basis:
    Press the Alt key to temporarily show the menu bar. After you make a selection it will disappear.
    Permanently:
    1. Click the Start button, type folder options and click the "Folder Options" link that appears.
    Accessing Folder Options from the Windows 7 Start button
    2. When the "Folder Options" multi-tabbed dialog box appears, click the "View" tab.
    3. Underneath "Advanced Settings", check "Always Show Menus".
    4. Click "OK" to close the dialog box.
  2. Posts : 72,051
    Hello Evan,
    That's why I had the menu bar link next to them for reference if they did not have it turned on.
  3. Posts : 1,065
    Is the Stack option still relevant in RTM? I can't find it.....?
  4. Posts : 72,051
    Hello Stu,
    You're not crazy, Stack By has been removed in the Windows 7 RTM. Seems I have missed updating this tutorial for this. I will update the screenshots later tonight.
  5. Posts : 1,065
    Is the 'Hide File Names' worth a little mention in this tut Shawn?
    File and Folder Arrangement - Group by - Sort by - Arrange by-12-09-2009-15-50-59.png
  6. Posts : 72,051
    It's a nice option, but it will be for a whole separate tutorial with other options of hiding the text.
    Folder Window Icon Text - Hide or Show File Names - Vista Forums
  7. Posts : 1
    Win7/Vista Dual Boot
    Brink said:
    Hello Stu,
    So Brink, does this mean that the Stack By feature is gone forever? It is one of my favorite folder features from Vista, rather disappointing to see it gone in Win7
  8. Posts : 72,051
    Hello Vash, and welcome to Seven Forums.
    I do not know if it'll be gone forever, but it did get cut in the RTM. Hopefully it will be added back sometime in the future through a update or a service pack.
  9. BFG
    Windows 7 Professional 32 Bit
    I was looking for a way to display all my pictures in one window so I thought I'd pass this tip along.
    Only the arrange by - ratings displays all items the items at once.
    Folder, month, date, and tag all create sub groupings.
    *Edit, stupid me, the arrange by day will work too*
