System Manufacturer/Model Number: Dell OS: Windows 7 Ultimate 64bit CPU: i3 Memory: 4Gb Graphics Card: Intel(R) HD Graphics Case: I prefer upper, but I will settle for lower Hard Drives: 350G built-in, 1T Seagate External, 2T Buffalo External Internet Speed: Yes, I would like some please... Other Info: Ham & Eggs - A days work for a chicken, but a lifetime of commitment for a pig.
Thanks for the confirmation Dave. It seems that so far most of what works in Windows 7 will be the same and work in Windows 8 Dev. Hopefully it will continue in the RTM. :)
How to Add "Log Off" Computer to the Desktop Context Menu in Windows 7
This will show you how to add or remove Log Off computer to the desktop context menu in Vista and Windows 7.
EXAMPLE: Log Off in Desktop Context Menu
173088
Add or Remove "Next desktop background" from Desktop Context Menu in Windows 7 and Windows 8
A desktop slideshow is a slideshow of wallpaper images (pictures) of your choice on your desktop.
When a desktop slideshow is being used in Windows 7 or Windows 8, Windows automatically adds Next...
Can anyone help me w/a little customization? In the attached picture, I want to move the StickyNote selection down into the New heading & also remove the (zipped) wording from New>Compressed (zipped) Folder. Anyone have any solutions?
The context menu ( right click desktop) has lost it. EX: click new .txt doc and nothing comes up. Some of the others do not work (most). I looked at a tutorial for it and there was some reg files to restore change etc.. Also seen a link for shmnview-x64.zip. Before I bork everything, is the...
