Problem Reports Shortcut - Create
    How to Create a "Problems Reports" Shortcut in Windows 7 and Windows 8
    This tutorial will show you how to create or download a Problem Reports shortcut that you can use or pin where you like to quickly view problem report details that you have in Windows 7 and Windows 8.
    EXAMPLE: Problems Reports
    OPTION ONE
    To Download a "Problems Reports" Shortcut
    1. Click/tap on the Download button below to download the file below.
    Problems_Reports.zip
    2. Save the .zip file to your desktop.
    3. Open the .zip file, and extract (drag and drop) the Problems Reports shortcut to your desktop.
    4. Unblock the Problems Reports shortcut.
    5. In Windows 7, you can now Pin to Taskbar or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    6. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    7. When finished, you can delete the downloaded .zip file if you like.
    OPTION TWO
    To Manually Create a "Problems Reports" Shortcut
    1. Right click or press and hold on an empty area on your desktop, and click/tap on New and Shortcut.
    2. Copy and paste the command below into the location area, and click/tap on the Next button. (see screenshot below)
    %windir%\explorer.exe shell:::{BB64F8A7-BEE7-4E1A-AB8D-7D8273F7FDB6}\pageProblems
    3. Type Problems Reports for the name, and click/tap on the Finish button. (see screenshot below)
    4. Right click or press and hold on the new Problems Reports shortcut, and click/tap on Properties.
    5. Click/tap on the Shortcut tab, then click/tap on the Change Icon button. (see screenshot below)
    6. In the line under "Look for icons in this file", type the location below, and press Enter. (see screenshot below)
    %windir%\System32\ActionCenterCPL.dll
    7. Select the icon highlighted in blue above, and click/tap on OK. (see screenshot above)
    NOTE: You can use any icon that you would like instead though.
    8. In Windows 7, you can now Pin to Taskbar or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    9. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
  1. Posts : 19,383
    Excellent Brink - that will be very useful in helping troubleshoot for people here.
  2. Posts : 8,679
    Interesting. Nice one Shawn.
  3. Posts : 72,050
    Thanks guys. :)
  4. Posts : 2,177
    Windows 8.1 Pro x64
    Good stuff!
    I'm sure i will find good use for this :)
