Windows 7: Visual Effects Settings - Change
06 Dec 2010   #30
Omber
Win 7 Pro (64 and 32bit)
Hi Brink,
Do you have one reg file that would just disable everything in that window?
I downloaded the individual registry files and combined them but after running the reg entry, the options are still checked in - any idea why?
Thanks!!
06 Dec 2010   #31
Brink
64-bit Windows 10 Pro
Hello Omber, and welcome to Seven Forums.
Did you restart the computer afterwards?
06 Dec 2010   #32
Omber
Quote   Quote: Originally Posted by Brink View Post
Hi Brink,
Yes I did.
06 Dec 2010   #33
Brink
It seems to be a quirk with the checkmarks remaining checked in Visual Effects, but the changes are actually still made.
08 Mar 2012   #34
windowasher
Win7|8 x64|x86 Starter|Home|Prof.|Ent.; WinSrv2k3/2k8... ^.^
Hey dude, thanks a lot not only for this great tutorial, but also for your last remark that changes in the registry wont be shown in the "Visual Effects Settings-Dialogue"!
08 Mar 2012   #35
Brink
Hello Windowasher, and welcome to Seven Forums.
Sometimes they do, and sometimes not. That's why I like to use the GUI to make the changes instead.
08 Mar 2012   #36
windowasher
Yey but in my special case i'd like to involve the changes in a sysprep-operation atuomatically.
I solved this issue by a <SynchronousCommand>-order in the answer file so that a batch-file starts at the end of the sysprep-process.
And this batch-file itself starts a reg-file in silent mode which makes the changes in the registry. ^^
So mutch work for such a little change - but thats the only way it works automatically i think :-/
23 Sep 2012   #37
chessian
Windows Vista/Windows 7
Very useful information for the novice people like me.
23 Jan 2014   #38
beranmuden
Windows 8 Pro x64
Actually, I've also tested this on Windows 8.1 x64 Pro, and I also stumbled into the fact the registry adjustments didn't became visible in the GUI checkboxes.
The reason in this case, was because I needed to change the following additional key:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects]
"VisualFXSetting"=dword:00000003
Where as stated elsewhere:
"VisualFXSetting"=dword:00000000 = Let Windows choose what's best for my computer
"VisualFXSetting"=dword:00000001 = Adjust for best appearance
"VisualFXSetting"=dword:00000002 = Adjust for best performance
"VisualFXSetting"=dword:00000003 = Custom
In short, if you want to make custom adjustments to the Performance Options with the use of registry settings, make sure you change the VisualFXSetting as well to let Windows know you're using custom settings.
@Bink could you please also make this tutorial available in on the EightForums?
This guide is very handy, and pretty much identical for Windows 8 users.
Grtz,
BM
23 Jan 2014   #39
Brink
Thank you BM, and welcome to Seven Forums.
I've updated OPTION TWO in this tutorial for this with all options. I'll get it added to the one at EightForums sometime today.
UPDATE:
Done at EightForums now.
Visual Effects - Adjust in Windows 8
Limited list for Visual Effects in Advanced system settings
Hi, I am currently having a problem with trying to set the thumbnail art for my MP3 folders. Previously I adjusted my settings to increase the speed of my PC by disabling Aero and other settings but cannot get the full list of settings in the "Visual Effects" menu. I know there is...
General Discussion
What are these visual effects?
So what do these visual effects do: Fade or slide menus into view, Fade or slide ToolTips into view, Fade out menu items after clicking, & Slide open combo boxes?
General Discussion
Visual effects won't save my settings
Hello, I'm having a hard time to save my settings on visual effects. Currently using admin account (uac off) on an ultimate copy, so when I go to Contron Panel > System > Advanced > Performance Settings and I choose Best Appearance everything gets checked and working. But when I reboot the...
Themes and Styles
How do I turn off visual effects?
How do I turn off visual effects? I donít like the way Win7 animates windows when maximizing and minimizing. Iíve know how to turn it off, but I want to turn it off permanently. Iíve been to System->Advanced->Performance Options->Visual Effects and unchecked the corresponding...
Customization
VLC disables W7 visual effects
Hey All RIght, I have used VLC for years now and not run into any issues but I seem to have an annoying issue at the moment. VLC "was" giving pixelated video in fullscreen mode. I solved this as stated on the VLC forums and put on DirectX Video Playback. Here is the source where I got that...
Music, Pictures & Video
Visual effects problem ?
On my Windows 7 all of the windows and desktop background seem to have some type of visual problem... Like the pixel looking mesh of things. A lot of times images kind of blur together too... what should i do about this ?:(
Customization
