Windows 7: Visual Effects Settings - Change
How to Change the Visual Effects Settings in Windows 7
Published 13 Jan 2009
Featured Tutorial
Online Scanners - Scan Suspicious Files on your PC
How to Scan Suspicious Files using Online Scanners
Secunia ONLINE Software Inspector
How to Scan for Common Software Vulnerabilities
Troubleshooting Windows 7 Failure to Boot
Screen Capture and Video Editing in High Quality
Windows 7 Installation - Transfer to a New Computer
How to Transfer your Complete Windows 7 Installation to a New Computer
Bootmgr - Move to C:\ with EasyBCD
How to Move Bootmgr to C:\ with EasyBCD
information   Information
This will show you how to change the visual effect settings you want to use for the appearance and performance of Windows 7 on your computer.
warning   Warning
If you make any changes in the Ease of Access Center (see screenshot below), the visual effects settings get reset back to the default setting automatically.
Note   Note
You will notice that not all visual effects options are available in the Windows 7 Starter and Home Basic editions since they do not include the Aero feature.
OPTION ONE
To Change Visual Effects Through System Properties
1. Do either step 2, 3, or 4 below depending on how you would like to open Visual Effects.
NOTE: Standard users will only be able to use step 4.
2. Open the Start Menu.
A) Right click on the Computer button and click on Properties.
B) Go to step 3A.
OR
3. Open the Control Panel (icons vew), and click on the System icon.
A) Click on the Advanced System settings link in the left blue pane, then close this window afterwards. (see screenshot below)
B) Under the Advanced tab and Performance section, click on the Settings button. (see screenshot below)
C) Go to step 5.
OR
4. Open the Control Panel (icons vew), and click on the Performance Information and Tools icon.
A) Click on the Advanced tools link in the left blue pane. (see screenshot below)
B) Click on the Adjust the appearance and performance of Windows link, then close this window afterwards. (see screenshot below)
5. You will now see the Visual Effects settings to select. (see screenshot below)
NOTE: You will notice that not all visual effects options are available in the Windows 7 Starter and Home Basic editions since they do not include the Aero feature.
Visual Effects Settings - Change-visual_effects-1.jpgVisual Effects Settings - Change-visual_effects-2.jpg
6. To Manually Select or Unselect Visual Effects
A) Select (dot) the Custom option. (see screenshots above)
B) Check the settings you want, and uncheck the settings you do not want.
Tip   Tip
If you want to help improve performance, then these are the most common ones to uncheck:
  • Animate windows when minimizing and maximizing
  • Animations in the taskbar and Start Menu
  • Enable transparent glass
  • Fade or slide menus into view
  • Fade or slide ToolTips into view
  • Fade out menu items after clicking
  • Show shadows under windows
  • Slide open combo boxes
C) Go to step 10.
7. For Best Appearance
A) Select (dot) the Adjust for best appearance option. (see screenshots below step 5)
NOTE: This will select all of the visual effect settings.
B) Go to step 10.
8. For Best Performance
A) Select (dot) the Adjust for best aperformance option. (see screenshots below step 5)
NOTE: This will unselect all of the visual effect settings.
B) Go to step 10.
9. To Let Windows 7 Choose the Visual Effects
A) Select (dot) the Let Windows choose what's best for my computer option. (see screenshots below)
NOTE: These screenshots are the usual items selected by Windows 7, but this will be based on what Windows 7 thinks will run best on your computer.
Visual Effects Settings - Change-windows1.jpgVisual Effects Settings - Change-windows2.jpg
10. Click on Apply and OK. (See screenshots above or below step 4)
NOTE: If you did step 2 or 3, then you will also need to click on OK in the screenshot below step 3B.
OPTION TWO
To Change Visual Effects Manually Through Registry Editor
Note   Note
You can click on the link below for these Visual Effects to see how to change them in the Registry Editor.
You will notice that the visual effects below with a * are not available in the Windows 7 Starter and Windows 7 Home Basic editions since they do not include the Aero feature.
Note   Note
The Visual Effects below will require more work to change them in the Registry Editor.
We will have to use the 3 sets of binary values below for the letter(s) of the Visual Effects below that you want to turn on or off, then convert each binary set to hex for the first 3 hex entries in the registry. This will be explained in detail on how to do this in the steps below.
Binary sets (3)
1001ABC0 00D1EF10 00000GH1
0=off and 1=on
Visual Effects and their assigned letters
(A) Smooth-scroll list boxes
(B) Slide open combo boxes
(C) Fade or slide menus into view
(D) Show shadows under mouse pointer
(E) Fade or slide ToolTips into view
(F) Fade out menu items after clicking
(G) Show shadows under windows
(H) Use Visual styles on windows and buttons
1. Using the binary sets above, change the letters in them to turn on (1) or off (0) for each corresponding visual effect.
For example, to turn them all off, I would change all letters in the binary sets to 0 (number zero) like below.
10010000 00010010 00000001
For example, to turn only the H visual effect on, I would change the letters in the binary sets like below.
10010000 00010010 00000011
2. Use a binary to hex converter to convert each separate binary set one by one to hex.
NOTE: Make note of these hex values when converted from the adjusted binary sets. They are what you will be using in regedit in step 7 below.
NOTE: Press enter after entering the binary value to convert it.
For example, from the example above to turn them all off, I would convert the binary sets (3) one by one to hex like below.
Binary
converted to
Hex
90 12 1
For example, from the example above to turn only the H visual effect on, I would convert the binary sets (3) one by one to hex like below.
Binary
converted to
Hex
90 12 3
3. Open the Start Menu, then type regedit in the search box and press enter.
4. If prompted by UAC, then click on Yes.
5. In regedit, navigate to the location below. (see screenshot below)
HKEY_CURRENT_USER\Control Panel\Desktop
6. In the right pane of Desktop, right click on UserPreferencesMask and click on Modify. (see screenshot above)
7. Change the first 3 hex values (ex: 90 12 03) below with the hex values you got from step 2, and click on OK. (see screenshot below)
8. Close regedit.
9. Log off and log on, or restart the computer to apply the changes.
Need more help? Try searching our extensive help and support site.
Loading
13 Jan 2009   #1
fireman604
windows 7 ultimate final Office 2007,27 Quad IMAC vm 7 64 bit
Homer, Alaska
Been there done that
All are checked. Set for all the bells and wistles.
Last edited by Brink; 13 Jan 2009 at 01:29 AM.. Reason: removed off topic material
13 Jan 2009   #2
I2aMpAnT
Microsoft Windows 7 x64 Ultimate
Cape Cod, MA
Quote   Quote: Originally Posted by fireman604 View Post
All are checked. Set for all the bells and wistles. I need help getting out of AGP mode I think. I can not install correct driver. By memory it is WDDM 1? not current video driver. Thanks
I keep everything on except for Animations, Fades and Slides. They hurt me the most in GPU.
08 Dec 2009   #3
ReanimationXP
Windows 7 x64 | Windows XP Pro x86
For anyone looking to change whether the popup / context menu animations are Fade or Slide (a dropdown that was available in XP), that tweak has been removed from the GUI in Windows 7.. another brilliant Microsoft change. This is particularly annoying since some remote desktop programs like LogMeIn change this setting.
It must now be manually changed in the registry if you wish to swap between Win98-style slide, or XP's fade. To do this, save either of the following as a .reg file using Notepad, and then double-click it to merge it into the registry.
For Win98 Slide effect:
___________________________________________
[HKEY_CURRENT_USER\Control Panel\Desktop]
"UserPreferencesMask"=hex:9e,28,07,80,12,00,00,00
____________________________________________
For the Default XP Fade effect:
"UserPreferencesMask"=hex:9e,3e,07,80,12,00,00,00
You'll need to log off and log back on before changes will take place. If you're someone who likes the Win98-style slide (unlike myself), be aware that it wasn't really intended to be included in Windows 7. Most menus will just 'appear' since the slide animation is too fast, or the menu is too big. However, menus will show a drop shadow under them. Enjoy!
31 Dec 2009   #4
j7ody
Windows 7 64bit
Good Afternoon to all,
Quick question on this subject. I have a Windows 7 Pro64 install with an admin account and a user account that I use every day.
When logged in as the user I change the preferences (giving Admin credentials to be able to open it), getting rid of animation and press save. When I restart and log back in, the visual effects are still set to Custom and some of the boxes are still unselected but minimize/maximise is re-selected as are shadows and most others.
Why are my settings not being remembered after a restart.... rather annoying to say the least
Jody
31 Dec 2009   #5
cjl2009
j7ody,
I was having the same problem with Windows not remembering the settings. The fix is to type SystemPropertiesPerformance in the Start menu's search bar, then choose your settings. The problem seems to be related to the UAC settings. I found the fix at this site Vista refuses to remember my aero visual effects settings - [H]ard|Forum
Hope that helps!
Cody
31 Dec 2009   #6
j7ody
Windows 7 64bit
Cody,
You are a legend..... this has been bugging me for about a month. Thank you!
Jody
12 Mar 2010   #7
wguru
Windows 7 Pro
Nice tutorial/guide (if you don't use Windows Classic).
12 Mar 2010   #8
Brink
64-bit Windows 7 Ultimate SP1 & Windows 8 Enterprise
Texas
Hello Wguru,
And if you do use Windows Classic, you can use the Advanced Appearance Settings (step 7 at link) instead to change those appearance settings. Plus, some in Folder Options. Not quite the same as the ones for Aero, but....
13 Mar 2010   #9
wguru
Windows 7 Pro
Thank you. Just mentioned it because I'm guessing if not the majority of 'us' prefer classic, quite a few do.
Again, great site. Kudos for all the efforts.
Comment
 Visual Effects Settings - Change problems?
Tutorial Tools
Similar help and support threads for: Visual Effects Settings - Change
Windows 7 Tutorial Category
Visual effects won't save my settings Themes and Styles
How do I turn off visual effects? Customization
VLC disables W7 visual effects Music, Pictures & Video
Speeding up visual effects? Customization
Visual effects problem ? Customization
