Take Ownership Shortcut
Page 12 of 45 FirstFirst ... 2101112131422 ... LastLast
  1. Posts : 3
    windows 7 home premium 64 bit
       #110
    It's working!
    Thank you for your tip, yes I ran both files! It appears that I'm finished doing what I set out to do. I'm going to keep this forum in my bookmarks. You made my day
  2. Posts : 72,058
       #111
    That's great news Newtech. I'm happy to hear that you got it sorted. :)
  3. Posts : 627
    Windows 7 Pro 64 bit
       #112
    Very cool, well done
  4. Posts : 1
    windows 7
       #113
    thnks very much. I think the problem was that by taking ownership of the folder i was not able to take the ownership of the subfolders .
  5. Posts : 54
       #114
    Super - going where no woman has gone before!!
    Avie
  6. Posts : 9
    Thank you very much !
  7. Posts : 12
    Win7 Pro SP1
       #116
    Will this work on Win Xp Pro Sp3?
    Hello guys!
    I'm new here and I would like to thank everybody in advance. I just recently re-install my system with Win Xp Pro Sp3 and i have some HD connected... and i was trying now to copy a folder from an eternal HD to and Internal one and I got this following msg:
    " Make sure disk is not full or write-protected" and can't copy my folder and i really need to copy that file to the specific HD cuz I did a back up and need bring back the folder.
    So I was wondering if having ownership on the folder will help but haven't found anywhere where to get a file like this one you have created here to use for XP.
    Thank you for any answer and suppor!
    Much appreciate it!!
  8. Posts : 18
    Windows Home Premium 64bit
       #117
    That's twice in a week that these forums have come to my rescue - thanks so much guys
  9. Posts : 4
    Windows 7 Ultimate 32-Bit
       #118
    Is it possible to change the registry entry for the right click take ownership? If I select multiple files, then each file is "changed" by taking ownership in an individual command prompt window. Yes, the window closes immediately after the command is completed, but I'd like to have all the selected file change ownership in a single command prompt box/window. Is this possible? I guess it will do what I want ONLY if you select an actual folder for taking ownership since all files lie in the same path - so one window to do all the permission changes. But not for individual files ? Even though all the files lie in the same folder path? Can it be done?
  10. Posts : 237
    Can I use this to take owner ship of the whole drive C if I want to?
