Take Ownership Shortcut
Page 18 of 45 FirstFirst ... 8161718192028 ... LastLast
  1. Posts : 72,051
       #170
    Yep, that would be correct.
  2. Posts : 476
    windows 7 ultimate 64bit
       #171
    thanks
    i did a mistake and i take ownership of w7 disk and xp
    can i undo?
    thanks
  3. Posts : 72,051
       #172
    Hello Drugo,
    Oh my. Are you having any issues from doing this? If not, then I wouldn't worry about it.
    If your are, then you could try doing a system restore at boot using a restore point dated before you did this to hopefully undo it in Windows 7. I'm not sure what the procedure is for in XP though.
  4. Posts : 2
    This script is the bomb! I can finally delete things again after trying everything Microsoft and other forums suggest!
  5. Posts : 23
    32 bit-ultimate windows7
       #174
    thanks it really solved my problem!
  6. Posts : 476
       #175
    Brink said:
    Hello Drugo,
    thanks
    but what does it do take the overship on a drive? like xp?
    i mean the effects and the bad effects?
    thanks again
  7. Posts : 72,051
       #176
    Drugo,
    Yes, if done used on a drive, it will change the ownership of every file and folder on the drive to you, and set the permissions of every file and folder to "Allow" you "Full Control".
    This could cause issue unknown issues with system access to these files, folders, or drive afterwards.
  8. Posts : 476
       #177
    Brink said:
    Drugo,
    thanks
    but it was so fast
    i mean when i did (my mistake) , it takes few seconds
    i meant for error , i clicked on my w7 and xp and take ownershipt
    but after my click ,i did notice a dos windows for 1 second and that's all
  9. Posts : 72,051
       #178
    Yep, it's scary that it doesn't take long to do it. Hopefully, you'll be ok and will not have any issues from doing so.
  10. Posts : 476
       #179
    i restored an w7 image
    but i have not an image about xp
    is there a way /tool /test to know that everything is ok ?
    by the way i'm right Take Ownership change all the permissions to normal user? right?
    thanks
    you are always very kind
    EDIT:
    do you know i'm thinking about Ultimate Windows Tweaker
    it can show Take Ownership only for files or folder
    a new script reg key , for files only or/and folder would be less dangerous
    thanks
    cheers
