Yanez,
Ah, so Comodo was blocking it from running. Glad you got it sorted. :)
For some reason this has stopped working. I tried re-do everything and it's still the same. Wonder if some windows update broke it.
Code:@echo Off reg query "HKU\S-1-5-19\Environment" If Not %ERRORLEVEL% EQU 0 ( cls & echo Schadenfreude.. pause & exit ) cls echo Add "Enable/Disable Thumbnails" to Context Menu: ( echo Registry = "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\IconsOnly" echo Set Command = CreateObject^("WScript.Shell"^) echo Thumbnails = Command.RegRead^(Registry^) echo If Thumbnails = 0 Then echo Command.RegWrite Registry, 1, "REG_DWORD" echo Else echo Command.RegWrite Registry, 0, "REG_DWORD" echo End If echo Command.SendKeys "{F5}" echo. ) > %SystemRoot%\Toggle-Thumbnails-ON-OFF.vbs echo. reg add "HKCR\Directory\Background\shell\Enable/Disable Thumbnails" /v "Icon" /d "imageres.dll,-72" /f reg add "HKCR\LibraryFolder\Background\shell\Enable/Disable Thumbnails" /v "Icon" /d "imageres.dll,-72" /f reg add "HKCR\Directory\Background\shell\Enable/Disable Thumbnails\command" /ve /d "WScript C:\Windows\Toggle-Thumbnails-ON-OFF.vbs" /f reg add "HKCR\LibraryFolder\Background\shell\Enable/Disable Thumbnails\command" /ve /d "WScript C:\Windows\Toggle-Thumbnails-ON-OFF.vbs" /f echo. :: echo Remove "Enable/Disable Thumbnails" from Context Menu: :: reg delete "HKCR\Directory\Background\shell\Enable/Disable Thumbnails" /f :: reg delete "HKCR\LibraryFolder\Background\shell\Enable/Disable Thumbnails" /f :: echo. pause & exit
