Presentation Mode - Change
Page 1 of 3 123 LastLast
    How to Change the Windows 7 Display Presentation Mode
    This will show you how to either display the Windows 7 desktop on the Computer only, Duplicate on both computer monitor and external display, Extend to all displays, or show only on a second screen or Projector.
    The application file for this is located at:
    C:\Windows\System32\DisplaySwitch.exe.
    OPTION ONE
    To Change Display Presentation Mode in GUI
    1. Press the Windows Key + P.
    A) Go to step 3.
    OR
    2. Open the Start Menu, then type displayswitch.exe in the search box and press Enter. (see screenshot below)
    3. Select the option that you want Windows 7 to be displayed on. (see screenshot below)
    NOTE: If you wanted to cancel and close this without making or selecting an option, then you can just click on a empty area on your desktop to do so.
    • Computer only - This shows your desktop only on your main display screen.
    • Duplicate - This shows your same desktop on both your computer display screen(s) and a connected external projector.
    • Extend - This extends your desktop from your computer display screen(s) and a connected external projector.
    • Projector only - This shows your desktop only on an external projector.
    OPTION TWO
    To Change Display Presentation Mode in Command Prompt
    1. Open a command prompt.
    2. In the command prompt, copy and paste the command in bold below for what you would like to do, and press Enter.
    • DisplaySwitch.exe /internal
      • (Computer only) This shows your desktop only on your main display screen.
    • DisplaySwitch.exe /clone
      • (Duplicate) This shows your same desktop on both your computer display screen(s) and a connected external display or projector.
    • DisplaySwitch.exe /extend
      • (Extend) This extends your desktop from your computer display screen(s) and a connected external display or projector.
    • DisplaySwitch.exe /external
      • (Projector only) This shows your desktop only on an external display or projector.
    3. When finished, you can close the command prompt.
  1. Posts : 4,282
    Another very nice feature. thanks John.
  2. Posts : 3
    6.1.7100
    My windows recognize my displays wrong.
    My monitor is the "projector" (2) and my tv is my "monitor" (1), wtf? ^^
    Anyone knows a way to change it?
    I have tried swap the cables, swap the hdmi entrance, nothing works.
    Currently using a ATI graphic card, so don't have the "display manager", driver beta, bla bla bla...
    []'s
  3. Posts : 72,049
    Hello Navossoc,
    Are you using the 9.4 ATI driver version for Windows 7? I have NVIDIA instead for graphics, but you should have a setting in the Catalyst Center to change the monitor identity somewhere I would think.
  4. Posts : 2,899
    right click the desktop and then click screen resolution...
    then on the your main display (the one you say is secondary...)
    tick this...
    and that should make it your main display...
  5. Posts : 72,049
    That could make a handy tutorial.
    Display - Change Main Display
    Thank you Mike.
  6. Posts : 3
    6.1.7100
    Thanks for the answer guys.
    Brink said:
    Hello Navossoc,
    Yes, currently using 9.4...
    This feature it's not avaliable at this time on ATI cards...
    Here:
    AMD Game Forums - "Display manager" tab - missing
    I see another user with the same problem.
    tick this...
    Yes, i already have made this a long time ago.
    Btw when i press WIN+P, i have to select "projector" as my screen, understand my problem? ^^
    Isn't a really problem, btw is annoying!
    See capture.png and capture2.png.
    I think he choose the tv because it has a higher resolution, i don't know...
    Swap cables, etc, don't work
    Any other ideas?
    Thanks!
    Ah Windows 7 build 7100
    PS: I don't have that "link" connect to a projector, any ideias too? ^^ weird things happen with me hahahaa.
    Attached Thumbnails Attached Thumbnails Presentation Mode - Change-capture.png   Presentation Mode - Change-capture2.png   Presentation Mode - Change-capture3.png
  7. Posts : 2
    Has anyone solved navossoc's problem?
    I have the exact same problem as navossoc. Can anyone help me please?
  8. Posts : 72,049
    Hello Catdog,
    Are you using the latest video driver?
    ATI: 9.12 + 9.12 hotfix
    NVIDIA: 195.81 beta
  9. Posts : 2
    updated video drivers
    yes i am
